ENS160, unable to get readings
Heyo !
My setup is an ESP32 with an ENS160, connected to a RPI 4B with HA OS.
Every seems to go well until it loops infinitly… I’v seen a similar issue but it was a power input issue and I’m at a stable 3V.
YAML
Secrets were modified
esphome:
  friendly_name: CIVIAQ
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "slk4g6s55f5s5d5f48f8sr8g8dv8sd8fd7fb7xc7v7t="
ota:
  password: "12345678912345678912345678912345"
wifi:
  ssid: !secret wifi_ssid
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: true
  - platform: ens160
    eco2:
    tvoc:
      name: "ENS160 Total Volatile Organic Compounds"
    aqi:
      name: "ENS160 Air Quality Index"
    update_interval: 10s
    address: 0x53
Logs
Initial setup
INFO ESPHome 2024.4.2
INFO Reading configuration /config/esphome/civiaq.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing civiaq (board: esp32dev; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
 - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 2.1.3
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- noise-c @ 0.1.4
|-- Wire @ 2.0.0
Compiling .pioenvs/civiaq/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/api/api_pb2_service.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/ens160/ens160.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/esp32/core.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/esp32/gpio.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/esp32/preferences.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/i2c/i2c.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/i2c/i2c_bus_arduino.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/i2c/i2c_bus_esp_idf.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/logger/logger.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/logger/logger_esp32.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/logger/logger_esp8266.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/logger/logger_host.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/logger/logger_libretiny.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/logger/logger_rp2040.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/md5/md5.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/mdns/mdns_component.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/mdns/mdns_host.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/mdns/mdns_libretiny.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/mdns/mdns_rp2040.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/network/util.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/ota/ota_backend_arduino_libretiny.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/ota/ota_backend_arduino_rp2040.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/ota/ota_component.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/sensor/automation.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/sensor/filter.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/sensor/sensor.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/socket/lwip_sockets_impl.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/socket/socket.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/wifi/wifi_component.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/wifi/wifi_component_libretiny.cpp.o
Compiling .pioenvs/civiaq/src/esphome/components/wifi/wifi_component_pico_w.cpp.o
Compiling .pioenvs/civiaq/src/esphome/core/application.cpp.o
Compiling .pioenvs/civiaq/src/esphome/core/color.cpp.o
Compiling .pioenvs/civiaq/src/esphome/core/component.cpp.o
Compiling .pioenvs/civiaq/src/esphome/core/component_iterator.cpp.o
Compiling .pioenvs/civiaq/src/esphome/core/controller.cpp.o
Compiling .pioenvs/civiaq/src/esphome/core/entity_base.cpp.o
Compiling .pioenvs/civiaq/src/esphome/core/helpers.cpp.o
Compiling .pioenvs/civiaq/src/esphome/core/log.cpp.o
Compiling .pioenvs/civiaq/src/esphome/core/ring_buffer.cpp.o
Compiling .pioenvs/civiaq/src/esphome/core/scheduler.cpp.o
Compiling .pioenvs/civiaq/src/esphome/core/string_ref.cpp.o
Compiling .pioenvs/civiaq/src/esphome/core/time.cpp.o
Compiling .pioenvs/civiaq/src/esphome/core/util.cpp.o
Compiling .pioenvs/civiaq/src/main.cpp.o
Building .pioenvs/civiaq/bootloader.bin
Creating esp32 image...
Successfully created esp32 image.
Generating partitions .pioenvs/civiaq/partitions.bin
Compiling .pioenvs/civiaq/libaf8/AsyncTCP-esphome/AsyncTCP.cpp.o
Compiling .pioenvs/civiaq/lib64d/WiFi/WiFi.cpp.o
Compiling .pioenvs/civiaq/lib64d/WiFi/WiFiAP.cpp.o
Compiling .pioenvs/civiaq/lib64d/WiFi/WiFiClient.cpp.o
Compiling .pioenvs/civiaq/lib64d/WiFi/WiFiGeneric.cpp.o
Archiving .pioenvs/civiaq/libaf8/libAsyncTCP-esphome.a
Compiling .pioenvs/civiaq/lib64d/WiFi/WiFiMulti.cpp.o
Compiling .pioenvs/civiaq/lib64d/WiFi/WiFiSTA.cpp.o
Compiling .pioenvs/civiaq/lib64d/WiFi/WiFiScan.cpp.o
Compiling .pioenvs/civiaq/lib64d/WiFi/WiFiServer.cpp.o
Compiling .pioenvs/civiaq/lib64d/WiFi/WiFiUdp.cpp.o
Compiling .pioenvs/civiaq/lib01c/FS/FS.cpp.o
Compiling .pioenvs/civiaq/lib01c/FS/vfs_api.cpp.o
Compiling .pioenvs/civiaq/libbc6/Update/HttpsOTAUpdate.cpp.o
Archiving .pioenvs/civiaq/lib64d/libWiFi.a
Compiling .pioenvs/civiaq/libbc6/Update/Updater.cpp.o
Compiling .pioenvs/civiaq/libe62/ESPAsyncWebServer-esphome/AsyncEventSource.cpp.o
Compiling .pioenvs/civiaq/libe62/ESPAsyncWebServer-esphome/AsyncWebSocket.cpp.o
Archiving .pioenvs/civiaq/lib01c/libFS.a
Compiling .pioenvs/civiaq/libe62/ESPAsyncWebServer-esphome/WebAuthentication.cpp.o
Archiving .pioenvs/civiaq/libbc6/libUpdate.a
Compiling .pioenvs/civiaq/libe62/ESPAsyncWebServer-esphome/WebHandlers.cpp.o
Compiling .pioenvs/civiaq/libe62/ESPAsyncWebServer-esphome/WebRequest.cpp.o
Compiling .pioenvs/civiaq/libe62/ESPAsyncWebServer-esphome/WebResponses.cpp.o
Compiling .pioenvs/civiaq/libe62/ESPAsyncWebServer-esphome/WebServer.cpp.o
Compiling .pioenvs/civiaq/lib333/DNSServer/DNSServer.cpp.o
Archiving .pioenvs/civiaq/lib333/libDNSServer.a
Compiling .pioenvs/civiaq/lib915/ESPmDNS/ESPmDNS.cpp.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_aead/chacha20poly1305/sodium/aead_chacha20poly1305.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_core/ed25519/core_ed25519.c.o
Archiving .pioenvs/civiaq/libe62/libESPAsyncWebServer-esphome.a
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_core/ed25519/core_ristretto255.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_core/ed25519/ref10/ed25519_ref10.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_hash/crypto_hash.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_hash/sha256/cp/hash_sha256_cp.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_hash/sha256/hash_sha256.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_onetimeauth/crypto_onetimeauth.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_scalarmult/crypto_scalarmult.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_scalarmult/curve25519/ref10/x25519_ref10.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_scalarmult/curve25519/scalarmult_curve25519.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_stream/chacha20/ref/chacha20_ref.c.o
Archiving .pioenvs/civiaq/lib915/libESPmDNS.a
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_stream/chacha20/stream_chacha20.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_stream/crypto_stream.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/crypto_verify/sodium/verify.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/sodium/codecs.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/sodium/core.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/sodium/runtime.c.o
Compiling .pioenvs/civiaq/lib3b8/libsodium/sodium/utils.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/backend/openssl/cipher-aesgcm.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/backend/ref/cipher-aesgcm.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/backend/ref/cipher-chachapoly.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/backend/ref/dh-curve25519.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/backend/ref/hash-blake2b.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/backend/ref/hash-blake2s.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/backend/ref/hash-sha256.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/backend/sodium/cipher-aesgcm.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/backend/sodium/cipher-chachapoly.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/backend/sodium/dh-curve25519.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/backend/sodium/hash-blake2b.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/backend/sodium/hash-sha256.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/crypto/aes/rijndael-alg-fst.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/crypto/blake2/blake2b.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/crypto/blake2/blake2s.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/crypto/chacha/chacha.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/crypto/donna/curve25519-donna-c64.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/crypto/donna/curve25519-donna.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/crypto/donna/poly1305-donna.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/crypto/sha2/sha256.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/crypto/sha2/sha512.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/crypto/x25519/x25519.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/protocol/cipherstate.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/protocol/dhstate.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/protocol/errors.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/protocol/handshakestate.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/protocol/hashstate.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/protocol/internal.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/protocol/names.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/protocol/patterns.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/protocol/rand_os.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/protocol/rand_sodium.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/protocol/randstate.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/protocol/signstate.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/protocol/symmetricstate.c.o
Compiling .pioenvs/civiaq/lib324/noise-c/protocol/util.c.o
Compiling .pioenvs/civiaq/lib4fc/Wire/Wire.cpp.o
Archiving .pioenvs/civiaq/lib324/libnoise-c.a
Compiling .pioenvs/civiaq/FrameworkArduino/Esp.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/FirmwareMSC.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/FunctionalInterrupt.cpp.o
Archiving .pioenvs/civiaq/lib4fc/libWire.a
Compiling .pioenvs/civiaq/FrameworkArduino/HWCDC.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/IPAddress.cpp.o
Archiving .pioenvs/civiaq/lib3b8/libsodium.a
Compiling .pioenvs/civiaq/FrameworkArduino/IPv6Address.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/MD5Builder.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/Print.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/Stream.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/StreamString.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/Tone.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/USB.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/USBCDC.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/USBMSC.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/WMath.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/WString.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/base64.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/cbuf.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-adc.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-bt.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-cpu.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-dac.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-gpio.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-i2c-slave.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-i2c.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-ledc.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-matrix.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-misc.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-psram.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-rgb-led.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-rmt.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-sigmadelta.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-spi.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-time.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-timer.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-tinyusb.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-touch.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/esp32-hal-uart.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/firmware_msc_fat.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/libb64/cdecode.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/libb64/cencode.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/main.cpp.o
Compiling .pioenvs/civiaq/FrameworkArduino/stdlib_noniso.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/wiring_pulse.c.o
Compiling .pioenvs/civiaq/FrameworkArduino/wiring_shift.c.o
Archiving .pioenvs/civiaq/libFrameworkArduino.a
Linking .pioenvs/civiaq/firmware.elf
RAM:   [=         ]  12.5% (used 40992 bytes from 327680 bytes)
Flash: [=====     ]  50.9% (used 934165 bytes from 1835008 bytes)
Building .pioenvs/civiaq/firmware.bin
esp32_create_combined_bin([".pioenvs/civiaq/firmware.bin"], [".pioenvs/civiaq/firmware.elf"])
Wrote 0xf57a0 bytes to file /data/build/civiaq/.pioenvs/civiaq/firmware-factory.bin, ready to flash to offset 0x0
======================== [SUCCESS] Took 133.87 seconds ========================
INFO Successfully compiled program.
esptool.py v4.7.0
Serial port /dev/ttyUSB0
Connecting....
Chip is ESP32-D0WD-V3 (revision v3.1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 24:dc:c3:9e:5e:44
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Flash will be erased from 0x00010000 to 0x000f5fff...
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Compressed 939936 bytes to 621917...
Wrote 939936 bytes (621917 compressed) at 0x00010000 in 15.8 seconds (effective 475.7 kbit/s)...
Hash of data verified.
Compressed 17440 bytes to 12128...
Wrote 17440 bytes (12128 compressed) at 0x00001000 in 0.7 seconds (effective 209.0 kbit/s)...
Compressed 3072 bytes to 144...
Wrote 3072 bytes (144 compressed) at 0x00008000 in 0.1 seconds (effective 326.5 kbit/s)...
Compressed 8192 bytes to 47...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 445.8 kbit/s)...
Leaving...
Hard resetting via RTS pin...
INFO Successfully uploaded program.
INFO Starting log output from /dev/ttyUSB0 with baud rate 115200
[13:35:30][I][logger:158]: Log initialized
[13:35:30][C][ota:483]: There have been 1 suspected unsuccessful boot attempts.
[13:35:30][D][esp32.preferences:114]: Saving 1 preferences to flash...
[13:35:30][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[13:35:30][I][app:029]: Running through setup()...
[13:35:30][I][i2c.arduino:218]: Performing I2C bus recovery
[13:35:30][C][ens160:052]: Setting up ENS160...
[13:35:30][C][wifi:038]: Setting up WiFi...
[13:35:30][C][wifi:051]: Starting WiFi...
[13:35:30][C][wifi:052]:   Local MAC: 24:DC:C3:9E:5E:44
[13:35:30][D][wifi:462]: Starting scan...
[13:35:30][D][ens160:172]: ENS160 readings unavailable - Normal Operation but readings not ready
[13:35:30][W][component:157]: Component wifi set Warning flag: unspecified
[13:35:34][I][ens160:179]: ENS160 readings unavailable - 1 hour startup required after first power on
[13:35:36][D][wifi:477]: Found networks:
[13:35:36][I][wifi:521]: - 'WIFI' [redacted]▂▄▆█
[13:35:36][D][wifi:522]:     Channel: 11
[13:35:36][D][wifi:523]:     RSSI: -65 dB
[13:35:36][D][wifi:523]:     RSSI: -70 dB
[13:35:36][D][wifi:523]:     RSSI: -75 dB
[13:35:36][D][wifi:523]:     RSSI: -81 dB
[13:35:36][D][wifi:526]: - [redacted] [redacted]▂▄▆█
[13:35:36][I][wifi:303]: WiFi Connecting to 'WIFI'...
[13:35:37][I][wifi:597]: WiFi Connected!
[13:35:37][C][wifi:408]:   Local MAC: 24:DC:C3:9E:5E:44
[13:35:37][C][wifi:413]:   SSID: [redacted]
[13:35:37][C][wifi:416]:   IP Address: 10.254.4.13
[13:35:37][C][wifi:420]:   BSSID: [redacted]
[13:35:37][C][wifi:421]:   Hostname: 'civiaq'
[13:35:37][C][wifi:423]:   Signal strength: -66 dB ▂▄▆█
[13:35:37][C][wifi:427]:   Channel: 11
[13:35:37][C][wifi:428]:   Subnet: 255.255.252.0
[13:35:37][C][wifi:429]:   Gateway: 10.254.7.254
[13:35:37][C][wifi:430]:   DNS1: 10.85.12.6
[13:35:37][C][wifi:431]:   DNS2: 10.85.12.3
[13:35:37][D][wifi:606]: Disabling AP...
[13:35:37][C][ota:096]: Over-The-Air Updates:
[13:35:37][C][ota:097]:   Address: civiaq.local:3232
[13:35:37][C][ota:100]:   Using Password.
[13:35:37][C][ota:103]:   OTA version: 2.
[13:35:37][C][api:025]: Setting up Home Assistant API server...
[13:35:37][I][app:062]: setup() finished successfully!
[13:35:37][W][component:170]: Component wifi cleared Warning flag
[13:35:37][W][component:157]: Component api set Warning flag: unspecified
[13:35:37][I][app:100]: ESPHome version 2024.4.2 compiled on May 15 2024, 13:33:52
[13:35:37][C][wifi:580]: WiFi:
[13:35:37][C][wifi:423]:   Signal strength: -64 dB ▂▄▆█
[13:35:37][C][logger:166]: Logger:
[13:35:37][C][logger:167]:   Level: DEBUG
[13:35:37][C][logger:169]:   Log Baud Rate: 115200
[13:35:37][C][logger:170]:   Hardware UART: UART0
[13:35:37][C][i2c.arduino:071]: I2C Bus:
[13:35:37][C][i2c.arduino:072]:   SDA Pin: GPIO21
[13:35:37][C][i2c.arduino:073]:   SCL Pin: GPIO22
[13:35:37][C][i2c.arduino:074]:   Frequency: 50000 Hz
[13:35:37][C][i2c.arduino:086]:   Recovery: bus successfully recovered
[13:35:37][I][i2c.arduino:096]: Results from i2c bus scan:
[13:35:37][I][i2c.arduino:102]: Found i2c device at address 0x53
[13:35:37][C][ens160:278]: ENS160:
[13:35:37][D][ens160:300]: Setup successful
[13:35:37][I][ens160:304]: Firmware Version: 5.4.6
[13:35:37][C][ens160:306]:   Address: 0x53
[13:35:37][C][ens160:307]:   Update Interval: 5.0s
[13:35:37][C][ens160:308]:   CO2 Sensor: 'ENS160 eCO2'
[13:35:37][C][ens160:308]:     Device Class: 'carbon_dioxide'
[13:35:37][C][ens160:308]:     State Class: 'measurement'
[13:35:37][C][ens160:308]:     Unit of Measurement: 'ppm'
[13:35:37][C][ens160:308]:     Accuracy Decimals: 0
[13:35:37][C][ens160:308]:     Icon: 'mdi:molecule-co2'
[13:35:37][C][ens160:309]:   TVOC Sensor: 'ENS160 Total Volatile Organic Compounds'
[13:35:37][C][ens160:309]:     Device Class: 'volatile_organic_compounds_parts'
[13:35:37][C][ens160:309]:     State Class: 'measurement'
[13:35:37][C][ens160:309]:     Unit of Measurement: 'ppb'
[13:35:37][C][ens160:309]:     Accuracy Decimals: 0
[13:35:37][C][ens160:309]:     Icon: 'mdi:radiator'
[13:35:37][C][ens160:310]:   AQI Sensor: 'ENS160 Air Quality Index'
[13:35:37][C][ens160:310]:     Device Class: 'aqi'
[13:35:37][C][ens160:310]:     State Class: 'measurement'
[13:35:37][C][ens160:310]:     Unit of Measurement: ''
[13:35:37][C][ens160:310]:     Accuracy Decimals: 0
[13:35:37][C][ens160:310]:     Icon: 'mdi:chemical-weapon'
[13:35:37][C][ens160:316]:   Compensation: Not configured
[13:35:37][C][captive_portal:088]: Captive Portal:
[13:35:37][C][mdns:115]: mDNS:
[13:35:37][C][mdns:116]:   Hostname: civiaq
[13:35:37][C][api:139]: API Server:
[13:35:37][C][api:140]:   Address: civiaq.local:6053
[13:35:37][C][api:142]:   Using noise encryption: YES
[13:40:30][I][ota:117]: Boot seems successful, resetting boot loop counter.
[13:40:30][D][esp32.preferences:114]: Saving 1 preferences to flash...
[13:40:30][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[13:50:37][E][api:128]: No client connected to API. Rebooting...
[13:50:37][I][app:125]: Forcing a reboot...
[13:50:37][W][wifi_esp32:482]: Event: Disconnected ssid='WIFI' bssid=[redacted] reason='Association Leave'
[13:50:37]ets Jul 29 2019 12:21:46
[13:50:37]
[13:50:37]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[13:50:37]configsip: 0, SPIWP:0xee
[13:50:37]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[13:50:37]mode:DIO, clock div:2
[13:50:37]load:0x3fff0030,len:1184
[13:50:37]load:0x40078000,len:13132
[13:50:37]load:0x40080400,len:3036
[13:50:37]entry 0x400805e4
[13:50:38][I][logger:158]: Log initialized
[13:50:38][C][ota:483]: There have been 0 suspected unsuccessful boot attempts.
[13:50:38][D][esp32.preferences:114]: Saving 1 preferences to flash...
[13:50:38][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[13:50:38][I][app:029]: Running through setup()...
[13:50:38][I][i2c.arduino:218]: Performing I2C bus recovery
[13:50:38][C][ens160:052]: Setting up ENS160...
[13:50:38][C][wifi:038]: Setting up WiFi...
[13:50:38][C][wifi:051]: Starting WiFi...
[13:50:38][C][wifi:052]:   Local MAC: 24:DC:C3:9E:5E:44
[13:50:38][D][wifi:462]: Starting scan...
[13:50:38][D][ens160:172]: ENS160 readings unavailable - Normal Operation but readings not ready
[13:50:38][W][component:157]: Component wifi set Warning flag: unspecified
[13:50:42][I][ens160:179]: ENS160 readings unavailable - 1 hour startup required after first power on
[13:50:44][D][wifi:477]: Found networks:
[13:50:44][I][wifi:521]: - 'WIFI' [redacted]▂▄▆█
[13:50:44][D][wifi:522]:     Channel: 11
[13:50:44][D][wifi:523]:     RSSI: -64 dB
[13:50:44][D][wifi:523]:     RSSI: -69 dB
[13:50:44][D][wifi:523]:     RSSI: -74 dB
[13:50:44][D][wifi:523]:     RSSI: -78 dB
[13:50:44][D][wifi:526]: - [redacted] [redacted]▂▄▆█
[13:50:44][I][wifi:303]: WiFi Connecting to 'WIFI'...
[13:50:45][I][wifi:597]: WiFi Connected!
[13:50:45][C][wifi:408]:   Local MAC: 24:DC:C3:9E:5E:44
[13:50:45][C][wifi:413]:   SSID: [redacted]
[13:50:45][C][wifi:416]:   IP Address: 10.254.4.13
[13:50:45][C][wifi:420]:   BSSID: [redacted]
[13:50:45][C][wifi:421]:   Hostname: 'civiaq'
[13:50:45][C][wifi:423]:   Signal strength: -64 dB ▂▄▆█
[13:50:45][C][wifi:427]:   Channel: 11
[13:50:45][C][wifi:428]:   Subnet: 255.255.252.0
[13:50:45][C][wifi:429]:   Gateway: 10.254.7.254
[13:50:45][C][wifi:430]:   DNS1: 10.85.12.6
[13:50:45][C][wifi:431]:   DNS2: 10.85.12.3
[13:50:45][D][wifi:606]: Disabling AP...
[13:50:45][C][ota:096]: Over-The-Air Updates:
[13:50:45][C][ota:097]:   Address: civiaq.local:3232
[13:50:45][C][ota:100]:   Using Password.
[13:50:45][C][ota:103]:   OTA version: 2.
[13:50:45][C][api:025]: Setting up Home Assistant API server...
[13:50:45][I][app:062]: setup() finished successfully!
[13:50:45][W][component:170]: Component wifi cleared Warning flag
[13:50:45][W][component:157]: Component api set Warning flag: unspecified
[13:50:45][I][app:100]: ESPHome version 2024.4.2 compiled on May 15 2024, 13:33:52
[13:50:45][C][wifi:580]: WiFi:
[13:50:45][C][wifi:423]:   Signal strength: -67 dB ▂▄▆█
[13:50:45][C][logger:166]: Logger:
[13:50:45][C][logger:167]:   Level: DEBUG
[13:50:45][C][logger:169]:   Log Baud Rate: 115200
[13:50:45][C][logger:170]:   Hardware UART: UART0
[13:50:45][C][i2c.arduino:071]: I2C Bus:
[13:50:45][C][i2c.arduino:072]:   SDA Pin: GPIO21
[13:50:45][C][i2c.arduino:073]:   SCL Pin: GPIO22
[13:50:45][C][i2c.arduino:074]:   Frequency: 50000 Hz
[13:50:45][C][i2c.arduino:086]:   Recovery: bus successfully recovered
[13:50:45][I][i2c.arduino:096]: Results from i2c bus scan:
[13:50:45][I][i2c.arduino:102]: Found i2c device at address 0x53
[13:50:45][C][ens160:278]: ENS160:
[13:50:45][D][ens160:300]: Setup successful
[13:50:45][I][ens160:304]: Firmware Version: 5.4.6
[13:50:45][C][ens160:306]:   Address: 0x53
[13:50:45][C][ens160:307]:   Update Interval: 5.0s
[13:50:45][C][ens160:308]:   CO2 Sensor: 'ENS160 eCO2'
[13:50:45][C][ens160:308]:     Device Class: 'carbon_dioxide'
[13:50:45][C][ens160:308]:     State Class: 'measurement'
[13:50:45][C][ens160:308]:     Unit of Measurement: 'ppm'
[13:50:45][C][ens160:308]:     Accuracy Decimals: 0
[13:50:45][C][ens160:308]:     Icon: 'mdi:molecule-co2'
[13:50:45][C][ens160:309]:   TVOC Sensor: 'ENS160 Total Volatile Organic Compounds'
[13:50:45][C][ens160:309]:     Device Class: 'volatile_organic_compounds_parts'
[13:50:45][C][ens160:309]:     State Class: 'measurement'
[13:50:45][C][ens160:309]:     Unit of Measurement: 'ppb'
[13:50:45][C][ens160:309]:     Accuracy Decimals: 0
[13:50:45][C][ens160:309]:     Icon: 'mdi:radiator'
[13:50:45][C][ens160:310]:   AQI Sensor: 'ENS160 Air Quality Index'
[13:50:45][C][ens160:310]:     Device Class: 'aqi'
[13:50:45][C][ens160:310]:     State Class: 'measurement'
[13:50:45][C][ens160:310]:     Unit of Measurement: ''
[13:50:45][C][ens160:310]:     Accuracy Decimals: 0
[13:50:45][C][ens160:310]:     Icon: 'mdi:chemical-weapon'
[13:50:45][C][ens160:316]:   Compensation: Not configured
[13:50:45][C][captive_portal:088]: Captive Portal:
[13:50:45][C][mdns:115]: mDNS:
[13:50:45][C][mdns:116]:   Hostname: civiaq
[13:50:45][C][api:139]: API Server:
[13:50:45][C][api:140]:   Address: civiaq.local:6053
[13:50:45][C][api:142]:   Using noise encryption: YES
Flags
[13:2-:23][VV][i2c.arduino:176]: 0x53 TX 20
[13:26:23][VV][i2c.arduino:148]: 0x53 RX 8B
[13:26:23][V][ens160:157]: Status: ENS160 STATAS bit    0x1
[13:26:23][V][ens160:159]: Status: ENS160 STATER bit    0x0
[13:26:23][V][ens160:160]: Status: ENS160 VALIDITY FLAG 0x02
[13:26:23][V][ens160:162]: Status: ENS160 NEWDAT bit    0x1
[13:26:23][V][ens160:164]: Status: ENS160 NEWGPR bit    0x1
Sensor or sensor module?
3V or 3.3V?
Did you try 0x52 ?
Also:
“Note
On first power-up of the ENS160 sensor, there is a 1 hour initial startup delay before readings will be available. For subsequent starts or reboots, there is a 3 minute warm up period before readings are available. Also, be aware that the ENS160 can take up to 1 second for sucessive data measurements to be ready.”
Sensoror sensore module ?: Don’t know the difference, I use the Fermion ENS160 by DFRobot
3V or 3V3: 3V, I know it requires 3V3 but I don’t think 0.3V would cause problem, I might be wrong…
Didn’t try 0x52 since it worked fine 0x53
Regarding the timing thing, I already did the “1h but then 23h more and after, it’s only 3 min” but I’m redoing it. I should have an aswer around 12:00 A.M UTC
From your answer I expect module.
Since that module is made to work 3.3V and 5V as well, it might be quite tight with those limits.
“It worked fine 0x53” ??? Did I miss something?
Regarding the 0x53 adress, the ESP32 detected the ENS160 without problem and communication happens between the two.
So what has changed back then??
Hijacking this topic, as I have a similar issue I suppose. I’m on ESPHome 2024.7.2 and this is my yaml:
  - platform: uptime
  - platform: pm1006
    pm_2_5:
      name: "Air Pollutants"
      accuracy_decimals: 1
      filters:
        - sliding_window_moving_average:
            window_size: 10
            send_every: 10
  - platform: aht10
    variant: AHT20
    temperature:
    humidity:
  - platform: ens160_i2c
    eco2:
    tvoc:
    aqi:
    compensation:
      temperature: temperature
      humidity: humidity
Note, for the while being, I haven’t connected the pm1006; but this is my log:
[16:42:20][I][app:029]: Running through setup()...
[16:42:20][I][i2c.arduino:218]: Performing I2C bus recovery
[16:42:20][C][aht10:046]: Setting up AHT20
[16:42:20][C][ens160:052]: Setting up ENS160...
[16:42:20][E][component:119]: Component ens160_base was marked as failed.
[16:42:20][D][sensor:093]: 'Temperature': Sending state 28.19366 °C with 2 decimals of accuracy
[16:42:20][D][sensor:093]: 'Humidity': Sending state 60.98146 % with 2 decimals of accuracy
[16:42:27][C][i2c.arduino:071]: I2C Bus:
[16:42:27][C][i2c.arduino:072]:   SDA Pin: GPIO4
[16:42:27][C][i2c.arduino:073]:   SCL Pin: GPIO5
[16:42:27][C][i2c.arduino:074]:   Frequency: 50000 Hz
[16:42:27][C][i2c.arduino:086]:   Recovery: bus successfully recovered
[16:42:27][I][i2c.arduino:096]: Results from i2c bus scan:
[16:42:27][I][i2c.arduino:102]: Found i2c device at address 0x38
[16:42:27][I][i2c.arduino:102]: Found i2c device at address 0x53
[16:42:27][C][aht10:162]: AHT10:
[16:42:27][C][aht10:163]:   Address: 0x38
[16:42:27][C][aht10:167]:   Temperature 'Temperature'
[16:42:27][C][aht10:167]:     Device Class: 'temperature'
[16:42:27][C][aht10:167]:     State Class: 'measurement'
[16:42:27][C][aht10:167]:     Unit of Measurement: '°C'
[16:42:27][C][aht10:167]:     Accuracy Decimals: 2
[16:42:27][C][aht10:168]:   Humidity 'Humidity'
[16:42:27][C][aht10:168]:     Device Class: 'humidity'
[16:42:27][C][aht10:168]:     State Class: 'measurement'
[16:42:27][C][aht10:168]:     Unit of Measurement: '%'
[16:42:28][C][aht10:168]:     Accuracy Decimals: 2
[16:42:28][C][ens160:278]: ENS160:
[16:42:28][E][ens160:282]: Communication failed! Is the sensor connected?
[16:42:28][I][ens160:303]: Firmware Version: 0.0.0
[16:42:28][C][ens160:306]:   Update Interval: 60.0s
[16:42:28][C][ens160:307]:   CO2 Sensor: 'eCO2'
[16:42:28][C][ens160:307]:     Device Class: 'carbon_dioxide'
[16:42:28][C][ens160:307]:     State Class: 'measurement'
[16:42:28][C][ens160:307]:     Unit of Measurement: 'ppm'
[16:42:28][C][ens160:307]:     Accuracy Decimals: 0
[16:42:28][C][ens160:307]:     Icon: 'mdi:molecule-co2'
[16:42:28][C][ens160:308]:   TVOC Sensor: 'Tvoc'
[16:42:28][C][ens160:308]:     Device Class: 'volatile_organic_compounds_parts'
[16:42:28][C][ens160:308]:     State Class: 'measurement'
[16:42:28][C][ens160:308]:     Unit of Measurement: 'ppb'
[16:42:28][C][ens160:308]:     Accuracy Decimals: 0
[16:42:28][C][ens160:308]:     Icon: 'mdi:radiator'
[16:42:28][C][ens160:309]:   AQI Sensor: 'AQI'
[16:42:28][C][ens160:309]:     Device Class: 'aqi'
[16:42:28][C][ens160:309]:     State Class: 'measurement'
[16:42:28][C][ens160:309]:     Unit of Measurement: ''
[16:42:28][C][ens160:309]:     Accuracy Decimals: 0
[16:42:28][C][ens160:309]:     Icon: 'mdi:chemical-weapon'
[16:42:28][C][ens160:312]:     Temperature Compensation: 'Temperature'
[16:42:28][C][ens160:312]:     Device Class: 'temperature'
[16:42:28][C][ens160:312]:     State Class: 'measurement'
[16:42:28][C][ens160:312]:     Unit of Measurement: '°C'
[16:42:28][C][ens160:312]:     Accuracy Decimals: 2
[16:42:28][C][ens160:313]:     Humidity Compensation: 'Humidity'
[16:42:28][C][ens160:313]:     Device Class: 'humidity'
[16:42:28][C][ens160:313]:     State Class: 'measurement'
[16:42:28][C][ens160:313]:     Unit of Measurement: '%'
[16:42:28][C][ens160:313]:     Accuracy Decimals: 2
[16:42:28][C][ens160_i2c.sensor:028]:   Address: 0x52
[16:42:28][E][component:082]:   Component ens160_base is marked FAILED
I spotted the error quite quickly, as the address is wrong. Changing the address resulted in the expected
[16:53:25][D][ens160:172]: ENS160 readings unavailable - Normal Operation but readings not ready
message.
I since have changed the documentation, as that states that the default is 0x53, which it is not. It obviously depends very much on how the board is being built, and whether the pin is default up or down.
Anyway, I hope this helps someone :slight_smile:
had some similar issues with:
[15:50:37][I][i2c.arduino:096]: Results from i2c bus scan:
[15:50:37][I][i2c.arduino:102]: Found i2c device at address 0x38
[15:50:37][I][i2c.arduino:102]: Found i2c device at address 0x53
15:50:37][C][aht10:162]: AHT10:
[15:50:37][C][aht10:163]: Address: 0x38
[15:50:37][E][aht10:165]: Communication with AHT10 failed!
[15:50:37][C][ens160:278]: ENS160:
[15:50:37][E][ens160:282]: Communication failed! Is the sensor connected?
turns out REMOVING this line fixed it:
setup_priority: -100
That worked for me too.
