Entities Calendar - turn your entities into a calendar
Hi Steven,
Can you show an example how we can set a date entry to have it occurred on a yearly basis? I have tried your suggested config setup buy it is not working when I set the ‘nextoccur’ as a timestamp_attribute as per your suggestion. Here a copy of my config
    sensors:
       birthday_lisa:
         friendly_name_template: Lisa's Birthday
         value_template: '2020-11-09'
         device_class: timestamp
calendar:
  - platform: entities_calendar
    calendars:
      - name: Key Dates
        #icon: 'mdi:cake-variant'
        entities:
          - entity: sensor.birthday_lisa
            name: "Lisa's Birthday"
            all_day: true
            #start_time:
            #  timestamp_attribute: nextoccur
Thanks for your help.
You can use something like this:
    sensors:
      birthday_lisa:
        friendly_name: "Lisa's Birthday"
        value_template: >
          {% set bday_lisa = {
          "thisyear": strptime(now().year | string + '1109', '%Y%m%d'),
          "nextyear": strptime((now().year+1) | string + '1109', '%Y%m%d')
          {% if (bday_lisa.thisyear | as_timestamp() > now() | as_timestamp()) %}
          {{ bday_lisa.thisyear }}
          {% else %}
          {{ bday_lisa.nextyear }}
          {% endif %}
When the current date is before the birthday, the sensor value will be this year, if not then next year’s birthday
Thanks Rom, appears to work very well. Smart use of template scripting :slight_smile:
Kudos to you. Grateful for your help/
Hello, strange but I get 4 hours back on calendar.
Sensor template:
    sensors:
      event_appointments_echo:
        friendly_name: "Vlad Lenox Hill Echo"
        value_template: "2021-04-09"
        device_class: "timestamp"
        attribute_templates:
          start_time: '2021-04-09 09:25:00'
          end_time: '2021-04-09 10:25:00'
    calendars:
      - name: Appointments
        entities:
          - entity: sensor.event_appointments_echo
            all_day: false
            start_time:
              timestamp_attribute: start_time
            end_time:
              timestamp_attribute: end_time
In “Developer Tools” time is correct:
But on Calendar:
sensor1
Any suggestions? What I’m doing wrong?
I did study your calendar.py file and after adding “-04:00” to start_time and end_time everything is good. Solved
Is it possible to dynamically create the name? I’m pulling my last 20 cards from ClickUp and trying to get them in a calendar but no matter what I do, it won’t actually evaluate the expression. I’ve tried all sorts of combinations like below, but the name is always just whatever I put in (in this case: {{ state_attr(‘sensor.clickup’,‘name’) }}). It evaluates fine in Developer tools, just not here. Any ideas?
I’m pretty new to this so this is probably something obvious.
calendar:
    calendars:
      - name: Entities
        entities:
          - entity: sensor.clickup
            name: "{{ state_attr('sensor.clickup','name') }}"
            start_time:
              timestamp_in_state: true
            end_time:
Please forgive what is probably a stupid question but where exactly (which .yaml) do I add this “calendar” data ??
calendar:
    calendars:
      entities:
        - sensor.first_entity
        - sensor.second_entity
        - sensor.third_entity
I have installed the integration thru HACS (0.08) and restarted HA, but I can find no evidence of this integration and have no idea where to add any configs :slight_smile:
I tried adding this as a sensor:
    calendars:
        entities:
            all_day: false
            start_time:
            end_time:
But the validation failed:
Platform error sensor.entities_calendar - No module named 'custom_components.entities_calendar.sensor'
Is there a getting started guide for dummies like me :slight_smile:
OK, firat part solved:
configuration.yaml:
calendar: !include my_calendar.yaml
my_calendar.yaml:
  calendars:
    - name: Bin Collection
      entities:
        - entity: sensor.bin_collection_general
          name: General Waste Collection
        - entity: sensor.bin_collection_recycling
          name: Recycling Collection
        - entity: sensor.bin_collection_garden
          name: Garden Waste Collection
    - name: Other Calendar
      entities:
        - entity: sensor.date
And then a new menu "Calendar" appears in the left panel.
EDIT
Hmm, there does not seem to be any activity with this thread, is this integration still active / supported ?
How can I create calendar entities from a json source ?
I have a REST sensor that returns the Refuse collection in the following format:
  "20220509": [ "GARDEN" ],
  "20220514": [ "RECYCLING", "REFUSE" ],
  "20220519": [ "RECYCLING" ],
  "20220523": [ "GARDEN" ],
  "20220526": [ "RECYCLING" ]
I know how to iterate through dictionaries using templating, but how would I go about converting multiple calendar entities from a sensor / template that returns a JSON object as per the sample above ?
Any update on support for entities which are a specific time during a day?
@Steven_Rollason
After October update - this Addon stopped working :frowning:
The system cannot restart because the configuration is not valid: Platform error calendar.entities_calendar - cannot import name ‘CalendarEventDevice’ from ‘homeassistant.components.calendar’ (/usr/src/homeassistant/homeassistant/components/calendar/init.py)
A fix for this was in a beta version (0.0.9b0) but I’ve just pushed this as a non-beta release.
made a template for the afvalinfo HACS integration
and i was wondering if i is possible to have multiple events based on a comma seperated attribute
attribute info;
year_month_day_date: 2023-03-29
whole_year_dates: 2023-03-29, 2023-04-12, 2023-04-26, 2023-05-10, 2023-05-24, 2023-06-07, 2023-06-21, 2023-07-05, 2023-07-19, 2023-08-02, 2023-08-16, 2023-08-30, 2023-09-13, 2023-09-27, 2023-10-11, 2023-10-25, 2023-11-08, 2023-11-22, 2023-12-06, 2023-12-20
changing year_month_day_date to whole_year_dates will break the calender
now it will make an event on 2023-03-29
but then it will make one on 2023-03-29, 2023-04-12, 2023-04-26, 2023-05-10 etc
calendar:
  calendars:
    entities:
      - entity: sensor.gft
        start_time:
           timestamp_attribute: year_month_day_date
      - entity: sensor.kerstboom
        start_time:
      - entity: sensor.papier
        start_time:
      - entity: sensor.pbd
        start_time:
      - entity: sensor.restafval
        start_time:
      - entity: sensor.textiel
        start_time:
