My devices from Bond are shown here with a power switch (lightning bolt) vs showing a toggle switch. Is there a way I can change that to a toggle?
https://www.home-assistant.io/docs/configuration/customizing-devices/#assumed_state
Be aware though, as Home Assistant does not know the state of your switch via feedback, if the state is changed by something other than Home Assistant the toggle will get out of sync with the actual device state.
I see. It makes sense. Thanks!
