Entities Card replacement? - mushroom, tile
So maybe I’m missing something, but as far as I can tell, there is so direct replacement for the entities card??
Mushroom has the mushroom ENTITY card, which seems to only handle 1. Then HA gave us the Tile card, which ALSO only seems to handle 1.
Is there really no alternative to using the standard Entities Card to display several entities at once? For example, I just want 1 card that holds all my Occupancy Sensors to quickly view the state of each all on one card, but to keep with theming I was hoping to find something that better matched the mushroom/tile card appearance.
Am I missing something?
The Custom Stack-In Card may be a solution for you:
I heared about this (custom stack-in-card) as well BUT it is not maintained since 2020 + I tried to install and it is not working, compare also Card is nor working after install (HACS) · Issue #45 · custom-cards/stack-in-card (github.com)
Any alternative? Many thanks!
Works more-or-less ok so far.
Have some issues (see on github), can be fixed by card-mod.
