I tried that but couldn’t find anything useful there.
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'homeassistant/binary_sensor/0x00124b002513f8ec/contact/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00124b002513f8ec"],"manufacturer":"SONOFF","model":"Contact sensor (SNZB-04)","name":"SENSOR_WINDOW_04_GYM"},"device_class":"door","json_attributes_topic":"zigbee2mqtt/SENSOR_WINDOW_04_GYM","name":"SENSOR_WINDOW_04_GYM_contact","payload_off":true,"payload_on":false,"state_topic":"zigbee2mqtt/SENSOR_WINDOW_04_GYM","unique_id":"0x00124b002513f8ec_contact_zigbee2mqtt","value_template":"{{ value_json.contact }}"}'
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'homeassistant/binary_sensor/0x00124b002513f8ec/battery_low/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00124b002513f8ec"],"manufacturer":"SONOFF","model":"Contact sensor (SNZB-04)","name":"SENSOR_WINDOW_04_GYM"},"device_class":"battery","entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/SENSOR_WINDOW_04_GYM","name":"SENSOR_WINDOW_04_GYM_battery_low","payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/SENSOR_WINDOW_04_GYM","unique_id":"0x00124b002513f8ec_battery_low_zigbee2mqtt","value_template":"{{ value_json.battery_low }}"}'
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'homeassistant/sensor/0x00124b002513f8ec/battery/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00124b002513f8ec"],"manufacturer":"SONOFF","model":"Contact sensor (SNZB-04)","name":"SENSOR_WINDOW_04_GYM"},"device_class":"battery","enabled_by_default":true,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/SENSOR_WINDOW_04_GYM","name":"SENSOR_WINDOW_04_GYM_battery","state_class":"measurement","state_topic":"zigbee2mqtt/SENSOR_WINDOW_04_GYM","unique_id":"0x00124b002513f8ec_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}'
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'homeassistant/sensor/0x00124b002513f8ec/voltage/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00124b002513f8ec"],"manufacturer":"SONOFF","model":"Contact sensor (SNZB-04)","name":"SENSOR_WINDOW_04_GYM"},"device_class":"voltage","enabled_by_default":false,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/SENSOR_WINDOW_04_GYM","name":"SENSOR_WINDOW_04_GYM_voltage","state_class":"measurement","state_topic":"zigbee2mqtt/SENSOR_WINDOW_04_GYM","unique_id":"0x00124b002513f8ec_voltage_zigbee2mqtt","unit_of_measurement":"mV","value_template":"{{ value_json.voltage }}"}'
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'homeassistant/sensor/0x00124b002513f8ec/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00124b002513f8ec"],"manufacturer":"SONOFF","model":"Contact sensor (SNZB-04)","name":"SENSOR_WINDOW_04_GYM"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","json_attributes_topic":"zigbee2mqtt/SENSOR_WINDOW_04_GYM","name":"SENSOR_WINDOW_04_GYM_linkquality","state_class":"measurement","state_topic":"zigbee2mqtt/SENSOR_WINDOW_04_GYM","unique_id":"0x00124b002513f8ec_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_05_BEDROOM', payload '{"battery":100,"humidity":74.5,"linkquality":244,"power_outage_count":14,"pressure":1007.8,"temperature":18.6,"voltage":3005}'
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_11_OFFICE_ZOLI', payload '{"battery":100,"humidity":74.9,"linkquality":255,"temperature":18.1,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_09_UPSTAIRS_BATHROOM', payload '{"battery":100,"humidity":66.2,"linkquality":255,"temperature":20.4,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_13_UPSTAIRS_TERRACE', payload '{"battery":100,"humidity":84,"linkquality":255,"temperature":15.5,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'zigbee2mqtt/PLUG_01_KITCHEN_WATER_HEATER', payload '{"consumer_connected":true,"consumption":26.71,"current":0,"device_temperature":23,"energy":26.71,"linkquality":255,"power":0,"power_outage_count":4,"power_outage_memory":true,"state":"ON","update":{"state":"idle"},"update_available":false,"voltage":262}'
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_11_OFFICE_SASKA', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":255,"tamper":false,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_02_BEDROOM', payload '{"battery":90,"contact":true,"device_temperature":18,"linkquality":255,"power_outage_count":36,"voltage":2985}'
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'zigbee2mqtt/ziarovka', payload '{"brightness":1,"color_mode":"xy","color_temp":241,"linkquality":255,"power_outage_memory":false,"state":"OFF","update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'zigbee2mqtt/buttonsatnik', payload '{"action":null,"battery":100,"device_temperature":23,"linkquality":255,"power_outage_count":20,"voltage":3015}'
Zigbee2MQTT:info 2022-10-26 09:48:34: MQTT publish: topic 'zigbee2mqtt/pohyb satnik', payload '{"battery":89,"battery_low":false,"linkquality":255,"occupancy":false,"tamper":false,"voltage":2900}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/kocka', payload '{"action":null,"action_angle":null,"action_from_side":null,"action_side":null,"action_to_side":null,"angle":-16.66,"battery":83,"current":0,"device_temperature":18,"linkquality":255,"power":1510,"power_outage_count":98,"side":5,"voltage":2975}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_10_OFFICE_ZOLI', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":255,"tamper":false,"voltage":3100}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_09_UPSTAIRS_BATHROOM', payload '{"battery":9,"battery_low":false,"contact":true,"linkquality":255,"tamper":false,"voltage":2700}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_08_TOILET', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":255,"tamper":false,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_10_TOILET', payload '{"battery":100,"humidity":83.3,"linkquality":255,"temperature":17,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_04_STAIRCASE', payload '{"battery":100,"humidity":81.2,"linkquality":255,"temperature":16.8,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_03_STAIRCASE', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":255,"tamper":false,"voltage":3100}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_06_DOWNSTAIRS_BATHROOM', payload '{"battery":100,"humidity":75,"linkquality":255,"temperature":18,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_06_GAME_ROOM', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":255,"tamper":false,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_03_GAME_ROOM', payload '{"battery":100,"humidity":69.4,"linkquality":156,"temperature":16.4,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_07_ENTRANCE_HALL', payload '{"battery":100,"humidity":71.6,"linkquality":255,"temperature":18.4,"voltage":3100}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_01_KITCHEN', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":255,"tamper":false,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_08_KITCHEN', payload '{"battery":100,"humidity":71.9,"linkquality":255,"temperature":18.7,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_01_LIVING_ROOM', payload '{"battery":100,"humidity":72.6,"linkquality":255,"temperature":18.6,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_07_LIVING_ROOM', payload '{"battery":null,"battery_low":false,"contact":true,"linkquality":255,"tamper":false,"voltage":null}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_02_GYM', payload '{"battery":100,"humidity":71.3,"linkquality":232,"temperature":19.3,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_05_DOWNSTAIRS_BATHROOM', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":255,"tamper":false,"voltage":3100}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/LIGHTBULB_02_LIVING_ROOM_02', payload '{"brightness":26,"color":{"x":0.6307692307692307,"y":0.3230769230769231},"color_mode":"xy","color_temp":319,"linkquality":255,"state":"OFF"}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/LIGHTBULB_01_LIVING_ROOM_01', payload '{"brightness":26,"color":{"x":0.6307692307692307,"y":0.3230769230769231},"color_mode":"xy","color_temp":319,"linkquality":255,"state":"OFF"}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/PLUG_03_UPSTAIRS_TERRACE_UNUSED', payload '{"linkquality":255,"state":"OFF"}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/PLUG_02_BEDROOM_HEATER', payload '{"current":0,"energy":7.47,"linkquality":252,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":242}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/PLUG_06_GAME_ROOM_UNUSED', payload '{"current":0,"energy":6.29,"linkquality":255,"power":0,"power_outage_memory":"off","state":"OFF","voltage":241}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/PLUG_05_GYM_HEATER', payload '{"current":0,"energy":0.19,"linkquality":244,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":239}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/PLUG_07_CELLAR_WATER_HEATER', payload '{"current":8.75,"energy":47.92,"linkquality":236,"power":2114,"power_outage_memory":"on","state":"ON","voltage":241}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/PLUG_08_OFFICE_SASKA_HEATER', payload '{"current":0,"energy":4.6,"linkquality":255,"power":0,"power_outage_memory":"restore","state":"ON","voltage":241}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_12_OFFICE_SASKA', payload '{"battery":100,"humidity":77.6,"linkquality":216,"temperature":18.1,"voltage":3100}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_04_GYM', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":null,"tamper":false,"voltage":3100}'
Zigbee2MQTT:info 2022-10-26 09:48:35: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_02_BEDROOM', payload '{"battery":90,"contact":true,"device_temperature":22,"linkquality":255,"power_outage_count":36,"voltage":2985}'
Zigbee2MQTT:info 2022-10-26 09:49:21: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_07_ENTRANCE_HALL', payload '{"battery":100,"humidity":72.7,"linkquality":255,"temperature":18.4,"voltage":3100}'
Zigbee2MQTT:info 2022-10-26 09:49:34: MQTT publish: topic 'zigbee2mqtt/PLUG_06_GAME_ROOM_UNUSED', payload '{"current":0,"energy":6.29,"linkquality":255,"power":0,"power_outage_memory":"off","state":"OFF","voltage":241}'
Zigbee2MQTT:info 2022-10-26 09:49:34: MQTT publish: topic 'zigbee2mqtt/PLUG_02_BEDROOM_HEATER', payload '{"current":0,"energy":7.47,"linkquality":228,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":242}'
Zigbee2MQTT:info 2022-10-26 09:49:34: MQTT publish: topic 'zigbee2mqtt/PLUG_08_OFFICE_SASKA_HEATER', payload '{"current":0,"energy":4.6,"linkquality":255,"power":0,"power_outage_memory":"restore","state":"ON","voltage":242}'
Zigbee2MQTT:info 2022-10-26 09:49:34: MQTT publish: topic 'zigbee2mqtt/PLUG_02_BEDROOM_HEATER', payload '{"current":0,"energy":7.47,"linkquality":200,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":242}'
Zigbee2MQTT:info 2022-10-26 09:49:36: MQTT publish: topic 'zigbee2mqtt/PLUG_07_CELLAR_WATER_HEATER', payload '{"current":8.77,"energy":47.92,"linkquality":244,"power":2119,"power_outage_memory":"on","state":"ON","voltage":242}'
Zigbee2MQTT:info 2022-10-26 09:49:36: MQTT publish: topic 'zigbee2mqtt/PLUG_07_CELLAR_WATER_HEATER', payload '{"current":8.77,"energy":48,"linkquality":244,"power":2119,"power_outage_memory":"on","state":"ON","voltage":242}'
Zigbee2MQTT:info 2022-10-26 09:49:36: MQTT publish: topic 'zigbee2mqtt/PLUG_05_GYM_HEATER', payload '{"current":0,"energy":0.19,"linkquality":255,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":239}'
Zigbee2MQTT:info 2022-10-26 09:49:59: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_07_ENTRANCE_HALL', payload '{"battery":100,"humidity":72.7,"linkquality":255,"temperature":18.4,"voltage":3100}'
Zigbee2MQTT:info 2022-10-26 09:50:34: MQTT publish: topic 'zigbee2mqtt/PLUG_02_BEDROOM_HEATER', payload '{"current":0,"energy":7.47,"linkquality":224,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":243}'
Zigbee2MQTT:info 2022-10-26 09:50:34: MQTT publish: topic 'zigbee2mqtt/PLUG_06_GAME_ROOM_UNUSED', payload '{"current":0,"energy":6.29,"linkquality":255,"power":0,"power_outage_memory":"off","state":"OFF","voltage":243}'
Zigbee2MQTT:info 2022-10-26 09:50:34: MQTT publish: topic 'zigbee2mqtt/PLUG_05_GYM_HEATER', payload '{"current":0,"energy":0.19,"linkquality":255,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":241}'
Zigbee2MQTT:info 2022-10-26 09:50:34: MQTT publish: topic 'zigbee2mqtt/PLUG_07_CELLAR_WATER_HEATER', payload '{"current":8.83,"energy":48,"linkquality":244,"power":2145,"power_outage_memory":"on","state":"ON","voltage":243}'
Zigbee2MQTT:info 2022-10-26 09:50:34: MQTT publish: topic 'zigbee2mqtt/PLUG_02_BEDROOM_HEATER', payload '{"current":0,"energy":7.47,"linkquality":208,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":243}'
Zigbee2MQTT:info 2022-10-26 09:50:34: MQTT publish: topic 'zigbee2mqtt/PLUG_07_CELLAR_WATER_HEATER', payload '{"current":8.83,"energy":48.03,"linkquality":255,"power":2145,"power_outage_memory":"on","state":"ON","voltage":243}'
Zigbee2MQTT:info 2022-10-26 09:51:31: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_09_UPSTAIRS_BATHROOM', payload '{"battery":100,"humidity":64.9,"linkquality":255,"temperature":20.4,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:51:33: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_01_KITCHEN', payload '{"battery":100,"battery_low":false,"contact":false,"linkquality":255,"tamper":false,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:51:34: MQTT publish: topic 'zigbee2mqtt/PLUG_06_GAME_ROOM_UNUSED', payload '{"current":0,"energy":6.29,"linkquality":255,"power":0,"power_outage_memory":"off","state":"OFF","voltage":244}'
Zigbee2MQTT:info 2022-10-26 09:51:34: MQTT publish: topic 'zigbee2mqtt/PLUG_08_OFFICE_SASKA_HEATER', payload '{"current":0,"energy":4.6,"linkquality":255,"power":0,"power_outage_memory":"restore","state":"ON","voltage":243}'
Zigbee2MQTT:info 2022-10-26 09:51:34: MQTT publish: topic 'zigbee2mqtt/PLUG_02_BEDROOM_HEATER', payload '{"current":0,"energy":7.47,"linkquality":255,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":243}'
Zigbee2MQTT:info 2022-10-26 09:51:36: MQTT publish: topic 'zigbee2mqtt/PLUG_02_BEDROOM_HEATER', payload '{"current":0,"energy":7.47,"linkquality":255,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":243}'
Zigbee2MQTT:info 2022-10-26 09:51:37: MQTT publish: topic 'zigbee2mqtt/buttonsatnik', payload '{"action":null,"battery":100,"device_temperature":23,"linkquality":255,"power_outage_count":20,"voltage":3015}'
Zigbee2MQTT:info 2022-10-26 09:51:48: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_01_KITCHEN', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":255,"tamper":false,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:52:34: MQTT publish: topic 'zigbee2mqtt/PLUG_02_BEDROOM_HEATER', payload '{"current":0,"energy":7.47,"linkquality":220,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":244}'
Zigbee2MQTT:info 2022-10-26 09:52:34: MQTT publish: topic 'zigbee2mqtt/PLUG_08_OFFICE_SASKA_HEATER', payload '{"current":0,"energy":4.6,"linkquality":255,"power":0,"power_outage_memory":"restore","state":"ON","voltage":243}'
Zigbee2MQTT:info 2022-10-26 09:52:34: MQTT publish: topic 'zigbee2mqtt/PLUG_05_GYM_HEATER', payload '{"current":0,"energy":0.19,"linkquality":255,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":241}'
Zigbee2MQTT:info 2022-10-26 09:52:34: MQTT publish: topic 'zigbee2mqtt/PLUG_02_BEDROOM_HEATER', payload '{"current":0,"energy":7.47,"linkquality":240,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":244}'
Zigbee2MQTT:info 2022-10-26 09:52:35: MQTT publish: topic 'zigbee2mqtt/PLUG_07_CELLAR_WATER_HEATER', payload '{"current":8.8,"energy":48.03,"linkquality":232,"power":2139,"power_outage_memory":"on","state":"ON","voltage":243}'
Zigbee2MQTT:info 2022-10-26 09:52:35: MQTT publish: topic 'zigbee2mqtt/PLUG_07_CELLAR_WATER_HEATER', payload '{"current":8.8,"energy":48.11,"linkquality":240,"power":2139,"power_outage_memory":"on","state":"ON","voltage":243}'
Zigbee2MQTT:info 2022-10-26 09:52:36: MQTT publish: topic 'zigbee2mqtt/PLUG_06_GAME_ROOM_UNUSED', payload '{"current":0,"energy":6.29,"linkquality":255,"power":0,"power_outage_memory":"off","state":"OFF","voltage":243}'
Zigbee2MQTT:info 2022-10-26 09:52:36: MQTT publish: topic 'zigbee2mqtt/PLUG_02_BEDROOM_HEATER', payload '{"current":0,"energy":7.47,"linkquality":224,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":244}'
Zigbee2MQTT:info 2022-10-26 09:52:36: MQTT publish: topic 'zigbee2mqtt/PLUG_02_BEDROOM_HEATER', payload '{"current":0,"energy":7.47,"linkquality":220,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":244}'
Zigbee2MQTT:info 2022-10-26 09:53:01: MQTT publish: topic 'zigbee2mqtt/PLUG_01_KITCHEN_WATER_HEATER', payload '{"consumer_connected":true,"consumption":26.71,"current":0,"device_temperature":23,"energy":26.71,"linkquality":255,"power":0,"power_outage_count":4,"power_outage_memory":true,"state":"ON","update":{"state":"idle"},"update_available":false,"voltage":262}'
Zigbee2MQTT:info 2022-10-26 09:53:34: MQTT publish: topic 'zigbee2mqtt/PLUG_02_BEDROOM_HEATER', payload '{"current":0,"energy":7.47,"linkquality":244,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":243}'
Zigbee2MQTT:info 2022-10-26 09:53:34: MQTT publish: topic 'zigbee2mqtt/PLUG_05_GYM_HEATER', payload '{"current":0,"energy":0.19,"linkquality":255,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":240}'
Zigbee2MQTT:info 2022-10-26 09:53:34: MQTT publish: topic 'zigbee2mqtt/PLUG_07_CELLAR_WATER_HEATER', payload '{"current":8.79,"energy":48.11,"linkquality":236,"power":2130,"power_outage_memory":"on","state":"ON","voltage":242}'
Zigbee2MQTT:info 2022-10-26 09:53:34: MQTT publish: topic 'zigbee2mqtt/PLUG_08_OFFICE_SASKA_HEATER', payload '{"current":0,"energy":4.6,"linkquality":255,"power":0,"power_outage_memory":"restore","state":"ON","voltage":243}'
Zigbee2MQTT:info 2022-10-26 09:53:34: MQTT publish: topic 'zigbee2mqtt/PLUG_02_BEDROOM_HEATER', payload '{"current":0,"energy":7.47,"linkquality":220,"power":0,"power_outage_memory":"restore","state":"OFF","voltage":243}'
Zigbee2MQTT:info 2022-10-26 09:53:34: MQTT publish: topic 'zigbee2mqtt/PLUG_07_CELLAR_WATER_HEATER', payload '{"current":8.79,"energy":48.14,"linkquality":244,"power":2130,"power_outage_memory":"on","state":"ON","voltage":242}'
Zigbee2MQTT:info 2022-10-26 09:53:36: MQTT publish: topic 'zigbee2mqtt/PLUG_06_GAME_ROOM_UNUSED', payload '{"current":0,"energy":6.29,"linkquality":255,"power":0,"power_outage_memory":"off","state":"OFF","voltage":244}'
Zigbee2MQTT:info 2022-10-26 09:53:37: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_01_KITCHEN', payload '{"battery":100,"battery_low":false,"contact":false,"linkquality":255,"tamper":false,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:53:44: MQTT publish: topic 'zigbee2mqtt/SENSOR_WINDOW_01_KITCHEN', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":255,"tamper":false,"voltage":3000}'
Zigbee2MQTT:info 2022-10-26 09:54:06: MQTT publish: topic 'zigbee2mqtt/SENSOR_TEMPERATURE_13_UPSTAIRS_TERRACE', payload '{"battery":100,"humidity":84,"linkquality":255,"temperature":15.7,"voltage":3000}'
There are only 100 lines, so I suppose that the logs are either not shown in the UI or they get rotated. Do you know where can I access the full history? Or if they are rotated how to reconfigure HA to keep a longer history?
