I have updatet all ESP devices to 2023.4.4. The update process went fine, all successful.
All ESPs are conneting to Wifi, an i can see the logs from Home Assitant management page.
But all entities are not available.
So for testing i delete one ESP from the integration and restart HA. The deleted device is recocnized again an i can readd it.
But after restart HA again, the entities are lost again.
Any ideas why that happends and what to do?
Complete restart of my NUC HAOS Installtion also not fix the problem.
Here some logs, maybe something is obviously:
Logger: homeassistant.config_entries
Source: components/esphome/__init__.py:641
First occurred: 11:37:33 (3 occurrences)
Last logged: 11:37:33
Error unloading entry nous-a1t-002 for esphome
Error unloading entry nous-a1t-004 for esphome
Error unloading entry Raumsensor for esphome
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 543, in async_unload
result = await component.async_unload_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/esphome/__init__.py", line 647, in async_unload_entry
entry_data = await _cleanup_instance(hass, entry)
File "/usr/src/homeassistant/homeassistant/components/esphome/__init__.py", line 641, in _cleanup_instance
await data.client.disconnect()
File "/usr/local/lib/python3.10/site-packages/aioesphomeapi/client.py", line 298, in disconnect
await self._connection.disconnect()
File "/usr/local/lib/python3.10/site-packages/aioesphomeapi/connection.py", line 709, in disconnect
await self.send_message_await_response(
File "/usr/local/lib/python3.10/site-packages/aioesphomeapi/connection.py", line 606, in send_message_await_response
res = await self.send_message_await_response_complex(
File "/usr/local/lib/python3.10/site-packages/aioesphomeapi/connection.py", line 587, in send_message_await_response_complex
self.send_message(send_msg)
File "/usr/local/lib/python3.10/site-packages/aioesphomeapi/connection.py", line 499, in send_message
frame_helper.write_packet(message_type, encoded)
File "/usr/local/lib/python3.10/site-packages/aioesphomeapi/_frame_helper.py", line 348, in write_packet
self._proto.encrypt(
File "/usr/local/lib/python3.10/site-packages/noise/connection.py", line 132, in encrypt
raise NoiseHandshakeError('Handshake not finished yet!')
noise.exceptions.NoiseHandshakeError: Handshake not finished yet!
