Should I be concerned about this ?
As you can see they were there but start disappearing over time …
Yes.
Look in Settings → System → Logs for related errors.
I’m surprised the automation ran at all. Are you using the continue on error option in your automations?
Hi
I’m not sure they are running .
Manually seems ok . Strange how entities appear and disappear in trace for no obvious reason . Only see this in the logs not sure if related
No ‘continue ‘ just simple on off automation done in UI
Is this a case that the device drops off the network (Zha) - then automation doesn’t run as no device entities ? - but sometimes reconnects again …
Yeah that’s probably your issue.
I’ll stick more router devices near these relays .
Appreciated
When you look at your automation config does it look like this (missing devices)?
There might be an issue.
Hi
No - all the parameters are filled in
Cheers
I’m curious if anyone else has experienced this…
