I’m fairly certain others have experienced this, but searches aren’t returning anything.
I use the Home Assistant MacOS App to monitor my Office iMac. For example, I override lights turning off if the binary_sensor.office_imac_active sensor is on. Fairly regularly, however — and I’m guessing maybe due to the app updating itself — I find all of my sensors re-created with a _2 in the name which wrecks my automations. The fastest way I’ve found to reliably put things back to rights is to directly edit the core.entity_registry file, but that’s a hassle.
Does anyone else experience this same issue? What’s your approach to fixing it?
Just rename the entries in the UI. I get this occasionally with one of my MQTT integrations when it rwsrt and forgot to tell HA it did so it happily creates new entity_ids for me (how helpful)
Don’t go into the registry unless there’s ABSOLUTELY NO OTHER WAY that’s how you get an HA install that won’t start.
It happened again today. The solution was to just delete both devices – the old one with the right entity names as well as the new one with the incorrect entity names. When I made the MacOS HA App active, Home Assistant saw the device and immediately recreated all of the entities with all of the correct names. I didn’t even have to restart HA.
