When I click on an element on my floorplan that is an entity, it toggles on/off multiple times. The entity is in a group with action homeassistant toggle.
It seems to be a problem with 433 switches and lights, input_boolean and scripts. My Hue lights is not affected by this, and acts as intended.
Does everyone have this problem, or is there a fix to this?
Help is greatly appreciated!
I have the same problem but only with some of my 433 switches (my Nexa switches and my elro light switches), my others work fine as does my zwave switches.
My scripts does not toogle, but I get the error message warning: script xxx is already running in the homeassistant log. Do you not get this error?
Currently I don’t use scripts as it’s just more maintenance, I would prefer to sort out the cause. I think it may be to do with the number of repeats, tho’ why it should affect some 433 devices and not others I don’t know.
No, it is strange. According to this post Mqtt toggle switch in floorplan fires twice (off, then back on) it seems to be a problem with mqtt sensors and input_select too, in addition to 433 devices, input_boolean and scripts. So I really hope there is a solution out there!
