Entity Button Card Problem
Greetings,
I recently switched over from yaml to pure UI-Editor and I now have some problems getting some old functions to work. I have an Entity Button Card which I want to make a certain color when ON/OFF but it just stays the same gray at all times.
My Entity Button config:
  - entity: group.standard
    hold_action:
      action: none
    icon: 'mdi:home'
    tap_action:
      action: toggle
    theme: TEMA
    type: entity-button
My Theme:
frontend:
  javascript_version: auto
  themes:
    TEMA:
      primary-color: "#00bcd4"
      disabled-text-color: "#545454"
      divider-color: "rgba(255, 255, 255, 0.12)"
      paper-card-background-color: "#4e4e4e"
      paper-grey-200: "#191919"
      paper-item-icon-color: "#d3d3d3"
      paper-listbox-background-color: "#202020"
      paper-listbox-color: "#FFFFFF"
      primary-background-color: "#303030"
      primary-text-color: "#cfcfcf"
      secondary-background-color: "#2b2b2b"
      secondary-text-color: "#04a7bc"
      label-badge-background-color: "var(--secondary-background-color)"
      label-badge-text-color: "var(--text-primary-color)"
      paper-card-header-color: "#var(--paper-item-icon-color)"
      paper-grey-50: "var(--primary-text-color)"
      paper-item-icon-active-color: "var(--primary-color)"
      paper-item-icon_-_color: "var(--primary-text-color)"
      paper-slider-active-color: "var(--primary-color)"
      paper-slider-knob-color: "var(--primary-color)"
      paper-slider-knob-start-color: "var(--primary-color)"
      paper-slider-pin-color: "var(--primary-color)"
      paper-slider-secondary-color: "var(--light-primary-color)"
      paper-toggle-button-checked-ink-color: "var(--dark-primary-color)"
      paper-toggle-button-checked-button-color: "var(--primary-color)"
      paper-toggle-button-checked-bar-color: "var(--light-primary-color)"
      paper-toggle-button-unchecked-bar-color: "var(--primary-text-color)"
Kind regards,
Proxid
