I am building a new irrigiation component but the entities i createde do not show up as toggle able buttons in the ui.
Anyone knows what i am doing wrong?
class IrrigationZone(Entity):
"""Representation of an Irrigation zone."""
def __init__(self, irrigation_id, attributes):
"""Initialize a Irrigation program."""
self.entity_id = irrigation_id
self._name = attributes.get(ATTR_NAME)
self._switch = attributes.get(ATTR_SWITCH)
self._duration = int(attributes.get(ATTR_DURATION))
self._state = STATE_OFF
self._icon_on = attributes.get(ATTR_ICON,
DFLT_ICON_WATER)
self._icon_off = attributes.get(ATTR_ICON_OFF,
DFLT_ICON_WATER_OFF)
self._stop = False
self._template = attributes.get(ATTR_TEMPLATE)
self._runtime_remaining = 0
async def async_added_to_hass(self):
await super().async_added_to_hass()
""" house keeping to help ensure solenoids are in a safe state """
self.hass.bus.async_listen_once(
EVENT_HOMEASSISTANT_START, self.async_stop_switch())
return True
@property
def should_poll(self):
"""If entity should be polled."""
return False
@property
def name(self):
"""Return the name of the variable."""
if self._state == STATE_ON:
x = '{} remaining {} (m).'.format(
self._name, self._runtime_remaining
else:
x = '{} def. duration {} (m).'.format(
self._name, self._duration)
return x
@property
def icon(self):
"""Return the icon to be used for this entity."""
return self._icon_on
else:
return self._icon_off
@property
def is_on(self):
"""If the switch is currently on or off."""
return self._state == STATE_ON
def turn_on(self, **kwargs):
"""Turn the device on."""
DATA = {CONST_ENTITY: self.entity_id}
#await self.hass.services.async_call(DOMAIN,
# 'run_zone',
# DATA)
def turn_off(self, **kwargs):
"""Turn the device off."""
@property
def state(self):
"""Return the state of the component."""
return self._state
@asyncio.coroutine
async def async_update(self):
"""Update the state from the template."""
_LOGGER.info('async_update - %s', self.entity_id)
@asyncio.coroutine
async def async_stop_zone(self):
_LOGGER.warn('async_stop_zone - %s', self.entity_id)
self._stop = True
DATA = {ATTR_ENTITY_ID: self._switch}
await self.hass.services.async_call(CONST_SWITCH,
SERVICE_TURN_OFF,
DATA)
self.async_schedule_update_ha_state()
@asyncio.coroutine
async def async_stop_switch(self):
_LOGGER.warn('async_stop_switch - %s', self._switch)
SERVICE_TURN_OFF,
DATA)
@asyncio.coroutine
async def async_run_zone(self, DATA):
_LOGGER.info('async_run_zone - %s', self._name)
