Entity does not work in script and scenes
I have what seems to be a strange problem. I have a light that works fine from a button in lovelace, but if I use it in a script or scene it does not respond. The scenes/scripts have several lights in them and they work when running the script or scene. It’s the light.bordlampe_hjorne that does not respond.
I have changed the entity_id on that light a while back but it has worked after that.
Any ideas why?
- name: Livingroom normal
  entities:
    light.bordlampe_stue:
      state: on
      transition: 2
      brightness_pct: 90
    light.stalampe:
      state: on
      transition: 2
      brightness_pct: 100
    light.bordlampe_hjorne:
      state: on
      transition: 2
      brightness: 100
- name: Livingroom dim
  entities:
      state: on
      transition: 2
      brightness_pct: 30
    light.stalampe:
      state: on
      transition: 2
      brightness_pct: 55
      state: on
      transition: 2
      brightness: 0
ettermiddag:
  sequence:
  - service: light.turn_on
      entity_id: light.bordlampe_hjorne
      entity_id: light.kjokkenbenk
      entity_id: light.gang
      entity_id: light.stalampe
      entity_id: light.bordlampe_stue
  - service: switch.turn_on
      entity_id: switch.kjokken_lys
Any ideas why?
You mean the whole scene works, except for that one light?
Have you called the service “scene.reload” since changing the entity id? (Or I’d assume a server restart would do it, but it’s possible that scene.reload does something unique that doesn’t even happen on a restart). I’d try calling a reload, just in case scenes use some other persistent storage that is now out of sync.
Yes the whole scene works, but not that light. I use the light in several automations. One for turning the light on in the afternoon using a script and in a scene for turning it off when watching tv, and back on when pausing or turning the tv off. None worked. For the afternoon lights I put the light in a group and made the automation turn on the group. That worked.
Yesterday it suddenly worked in my Tv-scene as well, so it may be a problem with scenes not being realoaded. Even if I’ve had several reboots.
