duemes
(Joshua)
May 18, 2024, 6:21pm
1
I want to show only security sensors that are currently Opened
Heres what I have, but it doesn’t display anything (even when testing in the Closed state)
type: entity-filter
title: Doors and Windows Currently Open
show_header_toggle: false
entities:
- binary_sensor.back_door_door
- binary_sensor.deck_door_entry_door
- binary_sensor.front_door_door
- binary_sensor.back_door_entry_door
- binary_sensor.downstrs_bath_entry_door
- binary_sensor.kitchen_windo_entry_door
- binary_sensor.laundry_wind_entry_door
- binary_sensor.lt_grge_door_entry_door
- binary_sensor.office_window_entry_doors
state_filter:
- Closed
show_empty: true
Edwin_D
(Edwin D.)
May 18, 2024, 6:26pm
2
If you look at those entities in developer tools, you will see the state is either on or off. Closed is shown in the UI, but that is a translation. For me in Dutch it would say Gesloten. So if you change the state filter to on (for open), it will most likely work as expected.
duemes
(Joshua)
May 19, 2024, 3:25pm
3
Thanks Edwin
Setting the state_filter to ‘on’ did the trick
state_filter:
- 'on'
duemes
(Joshua)
May 19, 2024, 3:54pm
4
Would you know how to change the display name for some of these entities using the code above?
duemes
(Joshua)
May 19, 2024, 4:21pm
5
Found out how to do it
type: entity-filter
entities:
- entity: binary_sensor.front_door_door
