I am running HA OS 9.2 with Home Assistant 2022.10.5 on Proxmox.
I have glance card that has multiple binary_sensors and sensors with entity_filter. The binary_sensor icons all appear yellow when the condition for display is met. The sensors do not. Adding state_color: true has no impact on this. For example I have a 2 stage heat pump. The binary_sensor for ‘on’ will be yellow. ‘Stage 1’ or ‘Stage 2’ from the sensor will display the correct stage, but not appear yellow. In the attached screen shot my hot tub status and air pollution icons are examples of this behavior. I am unsure if this is expected behavior. I would like all of the icons on the glance card using entity_filter to be yellow when the conditions for display are met. Can anyone confirm this behavior is expected or have a solution if it is not?
Thank you
