Hi All,
I’ve been away for a while, comeback and found I need to bite the lovelace bullet.
I’m doing it via YAML mode
and I have an :-
lovelace:
mode: yaml
Statement in my configuration.
In my ui-lovelace.yaml file i have various views and within those various cards.
I have 3 chromecasts and the 2 off TV ones are powered from the TV’s so they drop out (see picture)
This looked fugly so I made it into an entity-filter (also in picture) The problem is I can’t seem to get a title to stick to it. I’ve tried various options followed the config suggestions but nothing helps and usually just drops the whole card (if it doesn’t turn it into one of the luvley red ones !)
here’s my config from the ui-lovelace.yaml
I’m prolly just doing something plain stupid but I can’t see it
Any help or suggestion would be welcome
I apreciate that this suggests something similar to Petro’s suggestion using conditional cards but, it seems a bit clunky for a simple list [Dynamically change lovelace card]
Cheers
Mutt
pointing me at something, I had read (but clearley don’t understand … still ! ; - ((( )
I eventually played with your suggestions until they provided the required output
I thought that YAML was supposed to be both a structured and contextual file, so views, beget cards and cards beget content. But it seems there is ‘type’ between them and that is more important. I’m going to have to read up on this - and more importantly study more examples.
It does seem that whatever you or I have tried we have not managed to get rid of the header toggle, is this a known bug then ? Has it been reported ? I’ll have a look through issues and report it if not
Your comment also helped me to realize that I didn’t even need the “show_header_toggle” where I originally had it. It was pointless since it wouldn’t do anything there in any way - either for the entity-filter card or the embedded glance card.
