I’m currently using the intesis home cloud service to control my air con units. I wanted to try and access the current temperature but as this is configured in the configuration.yaml file, none of the entities show up in the front end
I know the system can access this data because when i create a climate card on the dashboard it shows the current and target temps.
Is there a way i can access these? or where can i find the entity id that is being used to populate these
