Hi everybody,
I created an automation that open and close the roller using position setted by numeric helper… every this entities are settable by a section in home assistant. Now I want to set min value of range of max-position-helper entity equals to value of min-position-helper entity. It’s possible?
You can’t adjust the min and max values of an Input Number helper.
You could restrict its value with an automation: trigger off any change, condition to check if below your other helper, adjust if it is.
