Hi, I’m using node red for the first time. I am using the home assistant “current_state” node and I would need to also include the entity_id of the object that the node is processing in the msg_payload. In particular I would like the msg.payload of the node to be:
"data": {
"deviceId": "vmalertdev",
"text": "attention $entity_id"
So I need to include in text the value of entity_id processed by node “current state”.
Example: “text”: “attention door_sensor”
Fra
