I cannot change settings of the vacuum from the UI:
“This entity does not have a unique ID, therefore its settings cannot be managed from the UI.”
This is its state:
fan_speed_list:
- Silent
- Standard
- Medium
- Turbo
- Gentle
battery_level: 88
battery_icon: 'mdi:battery-90'
fan_speed: Standard
do_not_disturb: 'on'
do_not_disturb_start: '22:00:00'
do_not_disturb_end: '08:00:00'
cleaning_time: 23
cleaned_area: 22
cleaning_count: 134
total_cleaned_area: 9340
total_cleaning_time: 11959
main_brush_left: 100
side_brush_left: 175
filter_left: 125
sensor_dirty_left: 5
status: Cleaning
clean_start: '2020-03-30T12:07:28'
clean_stop: '2020-03-30T12:16:28'
friendly_name: Xiaomi Vacuum cleaner
supported_features: 14204
entity_id: rockrobo-105
This is the config:
xiaomi_aqara:
discovery_retry: 20
gateways:
- mac: 7811dcb78c58
host: 192.168.10.100
key: up99XXXXXXy98
vacuum:
- platform: xiaomi_miio
host: 192.168.10.105
token: 5352XXXXXXX744f
Setting entity_id
in either file config or web UI does not have an effect, I can only change the friendly name this way. One of the answers I found that I cannot set it as it is set by the integration (which is what, my Xiaomi Control Hub?), however the vaccum itself goes to the internet via wifi and at least in theory does not need a hub, or did Xiaomi screw this part too?
Is there a way to enable the vacuum settings from the UI? Thanks,
