Hi!
I’m trying to use the output of a ’nput_select
to switch on switch.
I have the following in configuration.yaml:
input_select:
consumer_solar_power:
icon: mdi:consolidate
options:
- "cumulus"
- "car"
- "deshumi"
then in the Automation:
alias: Test Automation
description: ""
- id: "on"
platform: numeric_state
entity_id: sensor.net_enphase_watt_now
above: input_number.solar_power_on
- id: "off"
below: input_number.solar_power_off
condition: []
- service: switch.turn_{{ trigger.id }}
entity_id: switch.{{ input_select.consumer_solar_power }}
mode: single
The 1st part with the trigger.id
is working fine, this has been tested with a hardcoded switch
but I can get the intity_id, it throws the following:
Error: Error rendering service target template: UndefinedError: 'input_select' is undefined
Thank you in advance for anyone who could share some pointers!
Raphaël
