Entity List nearly empty, showing different entries from time to time
Home Assistant 2023.1.0 (had this probem with 2022.12 and before as well)
Node Red 14.0.1
node-red-contrib-home-assistant-websocket
HaOS all on same VM (proxmox) with official add on.
When I want to edit existing nodes or create a new node, the dropdown usually shows all entities from Home Assistant. However, since a couple of weeks, the dropdown shows no entities at all,
or only a couple of entries
sometimes up to maybe 20, but way too less.
I rebooted the system often, restarted the plugin way too often.
log_level:trace in the plugin shows nothing but
8 Jan 02:11:05 - [trace] comms.open wI10ulbimoyNIeK(…)uOqqwZrbQ=
8 Jan 02:11:05 - [trace] comms.close wI10ulbimoyNIeK(…)uOqqwZrbQ=
whenever I edit the nodes.
