Entity Loop with a Service Template
I have a light automation script that checks a couple of things before choosing whether to turn a light on/off or do nothing. I’d like to use change this script so I can pass it a group of lights.
Here’s the original script.
script:
  light_automation:
    sequence:
    # only run if light automation is enabled
    - condition: state
      entity_id: input_boolean.light_automation
      state: 'on'
    # don't run if light in use by occupant
    - condition: template
      value_template: >-
        {% if ignore_user_state == 'true' %}
          true
        {% elif is_state('binary_sensor.' + light_name, 'off') %}
          true
        {% else %}
          false
        {% endif %}
    # only run if new state is on and light automation switch is on (sun has set)
    # or light is turning off
      value_template: >-
        {% if new_state == 'on' and is_state('binary_sensor.auto_light_on','on') %}
          true
        {% elif new_state == 'on' and is_state('binary_sensor.auto_light_on','off') %}
          false
        {% else %}
          true
        {% endif %}
    # turn off light user state automation
    - service: automation.turn_off
      data_template:
        entity_id: "automation.set_{{ light_name }}_user_state"
    - service_template: >-
        {% if new_state == 'on' %}
          light.turn_on
        {% else %}
          light.turn_off
        {% endif %}
      data_template:
        entity_id: "light.{{ light_name }}"
        brightness_pct: "{{ brightness }}"
    # delay to allow state changes to register
    - delay: '0:00:02'
    # turn light user state automation back on
    - service: automation.turn_on
      data_template:
Here is how I currently call the script.
  service:  script.light_automation
  data_template:
    entity_id: light.living_room_pot_lights
    new_state: 'on'
    brightness: 50
    ignore_user_state: 'true'
Here is what I have so far. Where I’m stuck is with the data template section.
{%- for entity_id in states.group.outside_doors.attributes.entity_id -%}
  {% set domain,name = entity_id.split('.') -%}
  {%- if ignore_user_state == 'true' or is_state('binary_sensor.' + name , 'off') %}
    {%- if  new_state == 'off' or (new_state == 'on' and is_state('binary_sensor.auto_light_on', ‘on’)) %}
          light.turn_on
        {% else %}
          light.turn_off
        {% endif %}
    {% else %}
      script.null_script
    {% endif %}
  {% else %}
    script.null_script
  {% endif %}
{% else %}
  script.null_script
{%- endfor %}
 WHAT DO I DO WITH THIS??
  data_template:
  entity_id: "light.{{ name }}"
