Entity Name Fix & Cleanup Process
I probably have an atypical setup, with 3 Zwave JS/UI instances, and I know I’ve moved things around, changed IPs, etc, etc, and that’s why I end up with a bunch of broken entities and cards and automations, and have to spend hours cleaning it up . . . but I digress.
It would be great if there was a workflow that could be triggered from a broken entity on a card/scene/automation/any place that “Entity Not Available” might be displayed. This workflow could jump to a developer tools tab that would show a reference to the missing entity and any OTHER references to this same missing entity, and then allow “connection” to a valid entity. This would eliminate one of the complexities of doing entity name cleanup, as it would give you a central spot for “broken” entity references.
As a bonus, this same area could show the old/stale entities that end up causing _2 and _3 iterations of entities, and provide a mechanism for merging/renaming/cleanup up these entities.
Hi benhanson,
I suggest installing Spook, It should be able to help straighten that up.
I suggest a little de-cluttering, however, sounds like you have build a dragon that is pretty tough to control there.
Yes, Spook is great for the things built in the UI. For yaml, Watchman is still great, those complement each other perfectly:
Note that if you use device actions, conditions etc, and the devices are no longer there, then it is impossible to tell what device was referenced. That is because the id’s used in device actions no longer have any information attached to it. That makes auto-fixing next to impossible, because no one ca tell what is what.
This is why this advice is there:
The answer to this problem: use entity_id’s everywhere. When devices are replaced, change the entity_id of the new entity to what it used to be for the old entity and everything starts working again. That is way easier then changing every reference to point to the new entity.
I’ll have to take a look at that. All-in-all, my system is actually quite stable and not much cruft, but my zwave environment involves 3 bridges due to: detached garage, and another outbuilding. I’ve also upgraded/swapped zwave sticks. So it’s just been those transitions that interject a bunch of entity chaos.
Zwave mesh network is completely capable of handling a hundred devices,
It’s primarily a distance, foil faced insulation and metal siding issue. Also found that some devices, Schlage locks for instance, don’t work well if they aren’t directly connected to the controller.
