- type: entities
entities:
- entity: sensor.my_blah_blah
the name will override sensor.my_blah_blah's friendly_name in the ui.
friendly_name is created by the user. If not, it defaults to the object_id of sensor.my_blah_blah, which is my_blah_blah.
I have no idea where you’re getting: entity_name_override, device_name_type, or name_override as those are not valid entries/fields for entity inside entities or glance configurations.
Let say I have a device named my_device and the corresponding entity named switch.toto with the override name my_switch.
In this case entity card displays my_switch.
If there is no override name, entity card displays my_device_switch instead of switch.toto.
Well, override name just above the entity id into the entity dialog windows let believe it is an override of the name of the entity, not the name of the device.
NB. It displays my_device_switch, not just my_device.
Yes it is… I’ve said that bout 400000000000 times now. What are you not understanding?
item
description
example
domain
type of the device, i.e. light, switch, etc.
light
object_id
unique name inside the <domain>
living_room
entity_id
<domain>.<object_id>: A unique identifier that is unlike all other entity_id’s.
light.living_room
friendly_name
attribute that holds the name inside a state object. This is what you see in the UI
Living Room Light
Override Name
This is where you set the friendly_name in the UI.
Living Room Light
name
This is only inside the configuration of the device in lovelace or in the integration itself
Living Room Light
friendly_name attribute, override name in UI, name in configurations are all the same and have nothing to do with the domain, object_id, or entity_id. These “names” are what you see in the UI.
That’s how it always worked for me.
Now that I switched to a ui-lovelace file instead of managing it directly in the browser, something seems to have broken this logic.
At first I thought that I messed up the customizations. But when I click a card, it does show a configured friendly name for the sensor.
Another option was that the custom mini graph card I’m using doesn’t handle friendly names, but even adding the default Sensor card shows the same entity_id instead of friendly name.
In the entities directory I have a .yaml for each entity I wanted a customized name. So for the living room sensor the file name is sensor.aqara_thp_living_room.yaml with the following contents:
sensor.aqara_thp_living_room:
friendly_name: Temperatuur
UPDATE
Issue resolved. I needed to use include_dir_merge_named instead of include_dir_named.
Question related to this, on the default entities card, when a card’s name is specified by the area, it takes away the area’s name from any entities that share that (like Living Room Light becomes just “Light” in the Living Room card). I am trying to replicate this on my light dashboard. Do you know how I can accomplish this? I’ve not done too much digging so feel free to just link me in the right direction.
Edit: real-world I want to remove "Dining Room: from each of these:
Bump, does anyone know how the default lovelace setup removes the area name from the cards when named with the area in the device name (see prior post).
