Entity not available after move server
Hi guys,
I recently move my hassio (ha os) to a raspberry os. I restore my backup and everythink is working well and better.
I have just a problem, on notification I see these messages:
The following integrations and platforms could not be set up:
on logs:
Home Assistant Core
Setup failed for raspberry_pi: (DependencyError(…), ‘Could not setup dependencies: hassio’)
07:40:08 – (ERRORE) setup.py
Unable to set up dependencies of raspberry_pi. Setup failed for dependencies: hassio
Setup failed for hassio: Integration failed to initialize.
07:39:55 – (ERRORE) setup.py
Missing SUPERVISOR environment variable
07:39:55 – (ERRORE) hassio
Home Assistant Core
I understand that is cause I move os so I’m wonder how to remove these annoying notification.
I’ve already tried to remove database without success.
any ideas?
thanks
FIXED: just removed hassio in the .storage directory
