I recently updated to HA version 0.83.2 and noticed that all entities on my Hadashboard are now showing “entity not found”. I then decided to update Appdaemon to the latest version (appdaemon-3.0.2) and the entity not found remains.
always start by looking at your logs to find the problem and tell us what you dont understand there. (and show the logs)
thats way more helpfull then describing what you see.
That was it! I was using the old authentication method. I created a long lived token and changed it on my appdaemon’s configuration and everything is back to normal.
what exactly do I put in for “your TOKEN value”? Is it:
Bearer longhexvalue
or just
longhexvalue
I keep getting in the log (docker logs appdaemon)
2018-12-03 08:27:05.371112 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
Or maybe it is a problem with my HA_URL? Where does the docker container get it’s DNS from? I used a local hostname, which is resolved by pi-hole on another server.
At this point forward, you can edit configurations on your conf folder and Appdaemon will load them see the AppDaemon Installation page for full instructions on AppDaemon configuration. Have fun!
