I searched the discussion forum but I didn’t find anything like this issue… In the Hassio dashboard, I have an entity with a “Not found” title. It dosn’t give more information and I didn’t find anything suspicious in the log file of the home assistant. I also delete the assistant home database to recreate it. How can I delete this “Not Found” icon from the dahsboard?
Clicking on that badge should pop up a window with some idea what is expected.
You can then select “Configure UI” in the upper right.
Now select “Raw config editor” in the upper right.
Your issue is with one of the lines under “badges:”.
