Entity not found: sensor_dark_sky_wind_bearing
OK, sorry if i´m being a bit slow, but here´s my configs in a side-by-side view:
Colored text is from my configuration.yaml and white text is from my dash file.
It looks to me that all sensors are there, but then again i might have misunderstood the whole sensor installation concept. My theory was that i just don´t have the correct sensor names, but you say i need to install the sensors themselves too?
if you configured it right you will see all those sensors in your state page.
if not configured right you should find errors in your logging.
the entity names you see on your right (like sensor.darksky_temperature) must appaer in your states page.
i know that some of them have been changed since the widget was created, thats why 1 on 1 coping wont work.
and you need to figure out what your entities are called.
I had the same issue as above. I used Rene’s sample weather entry and added this to the configuation.yaml to get the sensors set correctly.
  • platform: darksky
    api_key: !funkyapigoeshere
    forecast:
    - 0
    monitored_conditions:
    - summary
    - icon
    - temperature
    - apparent_temperature
    - wind_bearing
    - wind_speed
    - pressure
    - precip_type
    - precip_intensity
    - precip_probability
    - humidity
