Hi All,
Got an issue that as usual many guys faced… Energy entity not listed in the energy dashboard.
I keep trying this for last couple of days, it came one time, then I tried to modify the code in ESP, then the energy sensor vanished in energy dashboard again.
Can any one please explain clearly what i need to do here? Please dont say device_class : enery and all.
You can see my developer tool shows all attributes , attached in the picture.
Below is the attribute for sensor.total_daily_energy
state_class: total_increasing
unit_of_measurement: Wh
device_class: energy
icon: mdi:flash-circle
friendly_name: Total Daily Energy
below is another sensor ---- sensor.total_daily_energy_2
unit_of_measurement: kWh
friendly_name: Total_Daily_Energy
I just clicked statistics “fix now” button. It automatically changed the unit of measurement and then i can easily see the the entity listed in dashboard. So, i did not change any code or anything. So, Statistics does this automatically ?
Yes it is automatic as far as the unit of measurement being changed in the database.
From what you are saying it sounds like in the statistics database it had a different unit of measurement than what it should have, but now it is fixed.
Yes. Infact i keep changed the unit of measurement kWh, W, Wh all in ESP YAML code. It did not work. Also, the develope tool states shows all good. But it was not working for me.
I have no idea about the statistics tool.
Yes because the entities themselves are valid and working fine.
The statistics are the long term database entries so when you change an entity it can cause a mismatch between new and old data which you need to resolve like that.
