hi, I’m using temperature sensor in HA and before updating HA to new version, when I click on the sensor it was showing last update. but after updating HA it’s not showing last update. even when I try to use secondary info it’s not showing that.
this is the error that shows on the top of the card:
Your config is not supported by the UI editor:
Expected a value of type `{entity,name,icon} | entity-id` for `entities.0.secondary_info` but received `"last-changed"`.
Falling back to YAML editor.
That is information telling you that the extra entity info you have added (correctly) is not (yet) supported by the graphical user interface editor and you have to edit it using the YAML version presented to you.
Save the card and it should display the secondary info.
