Entity or entities?
Is there a difference from
    - type: 'custom:mini-graph-card'
      entities:
        - entity: sensor.temp_attic
and
      entities:
        - sensor.temp_attic
They both work, so which method should I use?
Obviously you can use either.
But usually people use version 1 for regular lists of entities where it’s supported and version 2 is required if you are going to modify the entity in some way like adding additional info to the entity. For example using “secondary_info:” requires version 2.
Thanks. Today is a good day for learning new things.
