I configure home assistant (0.90.1) using yaml files and when accessing the entity registry from the front end I don’t see 95% of my entities listed. I also see one integration (which I added via the GUI) from the front end which means I cant use the area registry to assign entities to areas.
Is there a way to firstly rebuild the entity registry and secondly how do i get all my integrations to show in the front end so that I can assign areas?
BTW when I click on customization in the front end I see all of my entities
the entity registry only contains entities that get a unique id assigned to them. not all of them do and as far as i know you can’t put in the ones that don’t.
as far as areas are concerned i don’t know how to do that outside of the gui for the entity. you might have to hit up a dev in some way.
