I’ve run into a problem where the UI is not updating as the devices state changes. For example, I have a motion sensor that works in association with a bulb. When the sensor is triggered, the bulb turns on, when reset the bulb turns off, all fine. But in the UI, the sensor motion status is, for one sensor, always “Detected” and for two others, its always “Clear”. Also, the luminance value from one of my sensors is similarly never updated. In all cases, I can see the state changes in the zwavejsmqtt control panel under each devices settings. As an example, I’ve attached the luminance reported in the control panel, but no corresponding change in the UI.
The case is similar for the motion sensors. I can see state changes in the control panel, but no update in the UI.
I’m still pretty new to all of this, by the way.
All suggestions welcome.
