Hello!
I’m just starting my adventure with HA and just learning the basic stuff.
Here’s the problem I need help with. I have a device that exposes REST API. I can get certain values with RESTful sensor and also change the device’s state with RESTful command. However, this is the thing.
The device has configurable profiles, each profile sets the certain number of parameters. A user can create as many profiles as they want. I can get the list of existing profiles with the REST, here’s the response.
"thermostat_ext_modes_config":{
"0":{"active":true,"name":"Economy","schedule_number":null,"zone_sensors":{"1":1,"0":null},"zone_temp":{"1":15.0,"0":false}},
"1":{"active":true,"name":"Comfort","schedule_number":null,"zone_sensors":{"1":1,"0":null},"zone_temp":{"1":23.0,"0":65.0}},
"2":{"active":true,"name":"Schedule","schedule_number":null,"zone_sensors":{"1":0},"zone_temp":{"1":25.0},"hidden":true},
"3":{"active":true,"name":"Warmer","schedule_number":null,"zone_sensors":{"1":0,"0":null},"zone_temp":{"1":25.0,"0":65.0},"hidden":false},
"4":{"active":true,"name":"Summer","zone_sensors":{"0":null,"1":null},"zone_temp":{"0":65.0,"1":false},"schedule_number":null,"hidden":false},
And it also has a parameter which indicates the ID of the current active profile:
"thermostat_ext_mode":0,
I actually can activate the desired profile with REST command, but it’s static. Meaning I should already know the list of profiles and which ID is assigned to each profile.
What I’d like:
- have some card which lists all the available profiles
- switch between them clicking a button of a desired profile
Any idea how this could be implemented?
Here’s my current configuration:
- platform: rest
resource: https://zont-online.ru/api/devices
method: POST
timeout: 50
scan_interval: 60
force_update: true
headers:
X-ZONT-Client: !secret x_zont_client
X-ZONT-Token: !secret x_zont_token
Content-Type: application/json
payload: '{"load_io": true}'
picture: https://zont-online.ru/wp-content/themes/zont/images/logo-footer.svg
icon: https://zont-online.ru/wp-content/themes/zont/images/thumb_icon/gsm.svg
value_template: '{{ value_json.ok }}'
json_attributes_path: "$.[0]"
json_attributes:
- thermometers
- io
- thermostat_ext_mode
- thermostat_ext_modes_config
- id
rest_command:
zont_set_comfort:
url: https://zont-online.ru/api/update_device
method: POST
headers:
payload: '{"device_id": xxxxx,"thermostat_ext_mode": 1 }'
template:
- sensor:
# Thermostat mode
- name: "Curent mode"
state: >
{% if state_attr('sensor.zont', 'thermostat_ext_mode') is not none %}
{% set mode = '' ~ state_attr('sensor.zont', 'thermostat_ext_mode') ~ '' %}
{{ state_attr('sensor.zont', 'thermostat_ext_modes_config')[mode].name }}
{% endif %}
