Entrematic / Amarr Garage Doors?
First off, I’ve found this forum very helpful. Newbie here and had a bit of problem with my Nest thermostat initially, but a proper search yielded the answer.
First question is whether anyone has any experience or suggestions for getting my garage door control setup? It’s an Amarr door. The current app (Android) is called “Entrematic”. It’s a wifi-enabled door and using a wifi snooper, I can see the door and it’s IP address. Searching for Amarr or Entrematic didn’t yield any immediate answers. I see references to “Garageio” and a few others appearing fairly often.
Any initial suggestions welcome.
Sorry… giving this one bump in case someone else stumbles across this. There’s got to be an API or something “exposed” to allow WiFi control over this door, right? Yes… still a newbie, but trying to research and learn. So far, I’ve got 3 or 4 phone apps (Wink, Nest, Roomba, one more?) down to one with HA, and now it’s irking me that I can’t find any info on this door. Seems like it must be a reasonably popular model. They have an app, too. I don’t see any “developer” option like I’ve seen for the above three instances where you get an OAuth key or ID to plug in. Maybe this becomes a project and I get rich and famous? :slight_smile:
https://www.amarr.com/residential/opener_accessories
Hi there. I am using the same app for a door (Entrematic) and found half the solution :slight_smile:
1 - Entrematic can be added to Google Assistant
2 - you can link HA with GA
3 - you set a script in HA to open the Gate like you would verbally say to GA
However, my gate requires a PIN and from what I’ve read here, you cannot bypass that in HA without Nabu Cass :frowning:
