Enviroment Canada Weather Radar
Hello
I’m having trouble figuring out how to add environment Canada weather radar as a picture glance card on my dashboard. I believe the URL is:
Canadian Weather Radar - Environment Canada
My instructions are to add the following to my camera.yaml file:
Note: I do have the Environment Canada Integration card added.
Thanks in advance for any help that can be provided.
I am the author of the Australian weather radar card (https://github.com/Makin-Things/bom-radar-card).
I have recently found a new source of radar data that will allow it to work more globally. It will be a new card that I hope to make available soon. It will use data from rainviewer for a sample of what will be used see https://www.rainviewer.com/weather-radar-map-live.html
Cheers
Simon
The URL you posted leads to a web page containing many elements and not merely a solitary static image as is needed by the still_image_url option.
The Webpage card is a better fit for the URL you posted.
@mcoulton this new card might be a good option for you.
Thanks for the update. I’ll put it on my radar (pun) to check out.
Hello
I’ve installed the new weather radar card. Wow! This is exactly what I was looking for. Thanks you very much for all your efforts.
