Not sure even how to figure this out.
Running HA 100.3 in Docker and everything was running well until I did a server restart for a few changes I made in my snips_intent.yaml, automations.yaml, and ui_lovelave.yaml files.
After clicking the Restart option HA refuses to start and the home-assistant.log files has 1131 lines of errors like below (This is the end of the log file)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 190, in async_setup
hass, self
File "/usr/src/homeassistant/homeassistant/components/openuv/__init__.py", line 189, in async_setup_entry
await openuv.async_update()
File "/usr/src/homeassistant/homeassistant/components/openuv/__init__.py", line 281, in async_update
await asyncio.gather(*tasks)
concurrent.futures._base.CancelledError
2019-10-29 11:31:29 ERROR (SyncWorker_3) [concurrent.futures] exception calling callback for <Future at 0x7fe629352c10 state=finished raised RuntimeError>
File "/usr/src/homeassistant/homeassistant/components/aurora/binary_sensor.py", line 53, in setup_platform
add_entities([AuroraSensor(aurora_data, name)], True)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 200, in _schedule_add_entities
update_before_add,
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 77, in run_callback_threadsafe
loop.call_soon_threadsafe(run_callback)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 728, in call_soon_threadsafe
self._check_closed()
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 475, in _check_closed
raise RuntimeError('Event loop is closed')
RuntimeError: Event loop is closed
File "/usr/local/lib/python3.7/concurrent/futures/_base.py", line 324, in _invoke_callbacks
callback(self)
File "/usr/local/lib/python3.7/asyncio/futures.py", line 362, in _call_set_state
dest_loop.call_soon_threadsafe(_set_state, destination, source)
I reversed the additions I made to the files above and I’ve restarted the Docker container with no change.
