Environment Canada integration stopped working today
Yesterday the radar image on my dashboard using the environment canada integration stopped working. Specifically, camera.toronto_radar just shows black where the radar image should be. All the other entities associated with the integration are working. When I try to reload it, I get the message:
This entity is no longer being provided by the environment_canada integration. If the entity is no longer in use, delete it in settings.
Does anyone else have this issue? Does anyone know the github location for the developer?
Currently working for me using Burlington and Mississauga (likely the same radar reference as Toronto). Have you checked the integration entity itself to see if for some reason the entity_id has changed?
Elsewise both devs follow this forum topic regularly.
Started to work about a half an hour ago. Not sure if it was an environment Canada problem or not but I’m very grateful for the developers for making this so easy.
