I noticed in the last day or two that the add-on stop working. I’ve tried to reinstall with no luck.
Is anyone else having problems?
Mine is working, but I do see some error in the logs, what kind of problem do you have?
2023-08-25 11:36:26.240 ERROR (MainThread) [homeassistant.components.environment_canada] Unexpected error fetching environment_canada radar data: cannot identify image file <_io.BytesIO object at 0x7f2d878249f0>
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 283, in _async_refresh
self.data = await self._async_update_data()
File "/usr/src/homeassistant/homeassistant/components/environment_canada/__init__.py", line 117, in _async_update_data
await self.ec_data.update()
File "/usr/local/lib/python3.11/site-packages/env_canada/ec_radar.py", line 329, in update
self.image = await self.get_loop()
File "/usr/local/lib/python3.11/site-packages/env_canada/ec_radar.py", line 356, in get_loop
frames.append(await self._combine_layers(f, frame_times[i]))
File "/usr/local/lib/python3.11/site-packages/env_canada/ec_radar.py", line 258, in _combine_layers
radar = Image.open(BytesIO(radar_bytes)).convert("RGBA")
The error look like it lost the station IDs setting, did you try to remove it and reinstall?
Yes, that’s what I’m doing now. I removed it, and trying to install again.
I think you’re right about this. I just specified another location and it worked.
Is there anywhere I can check what the latest weather ID is, and just punch it in?
I think the app get the weather ID from the csv list Environment Canada - Home Assistant , if the ID has changed, you probably need to report an issue.
You can also follow this link How to Get Environment Canada Climate Station ID From Name | Michael Yu , the site has change, so you need to click around, I was able to find the station ID.
