I have had the envisalink integration working for a while (arm, disarm etc) but cannot figure out why the door and window sensors go back to closed state 5 seconds after the door is opened and is still open. I would expect the sensor to stay in the open state for as long as the door is actually open. I have seen many discussions about this but have not seen a solution. would love some help. (yes I tried taking quotes off type but that did not help either)
configuration.yaml
envisalink:
host: 192.168.xx.xx
panel_type: DSC
user_name: user
password: 1234
code: "1234"
port: 4025
evl_version: 4
keepalive_interval: 60
zonedump_interval: 10
timeout: 10
panic_type: Police
zones:
1:
name: "1-Dbl Garage and Mud Entry"
type: door
2:
name: "2-Front Door and Down Patio Entry"
type: "door"
3:
name: "3-Single Garage and Up Patio Entry"
type: "door"
4:
name: "4-Up Family Rm Windows"
type: "window"
5:
name: "5-Up Laundry Win"
type: "window"
6:
type: "door"
7:
name: "7-Dn Kitchen Win"
type: "window"
8:
name: "8-Dn Fam Rm Win"
type: "window"
9:
name: "9-Dn Hall Win"
type: "window"
10:
name: "10-Dn West Bed Win"
type: "window"
11:
name: "11-Dn Mid Bed Win"
type: "window"
12:
name: "12-Dn East Bed Win"
type: "window"
13:
name: "13-Green Rm Win"
type: "window"
14:
type: "door"
15:
name: "15-Up Motion Sensor"
type: "motion"
16:
name: "16-Down Motion Sensor"
type: "motion"
partitions:
1:
Thanks! I got it working using the examples above - when home assistant directly connects to the EVL board - The zones show open as expected. But uncovered another dynamic in my environment. Since the EVL board only accepts a single connection at a time I have been using DSCServer.jar to connect to the envisalink board and then my two platforms connect to DSCServer.jar simultaneously - hoobs and home assistant. DSCServer is running on a debian VM. on the hoobs side the zone shows open as expected for as long as the window is open. On the home assistant side the zone shows open, then still closes after about 30 seconds even if the window is still open. If anyone has any input would love to hear. I will post back as I diagnose this problem in my environment
I got a similar setup as yours, I have 2 Automation system connecting to ine DscServer.ra and door sensor appears closed after few minutes even if they are still open in Home assistant but not in Homeseer.
my solution was to connect directly to the evl4 board from home assistant, then i used the homekit bridge in home assistant to get alarm controls over to apple homekit on my iphone.
