I have gone over this, checked for extended characters and retyped it, but always get a fatal startup error,
"...expected <block end>, but found '<block mapping start>' line 117, column 3",
which is the second line below:
envisalink:
host: 192.168.1.10
panel_type: HONEYWELL
user_name: user
password: password
code: '1234'
port: 4025
evl_version: 4
keepalive_interval: 60
zonedump_interval: 30
panic_type: Police
zones:
1:
type: 'opening'
2018-02-02 11:30:22 ERROR (MainThread) [homeassistant.config] Invalid config for [envisalink]: required key not provided @ data[‘envisalink’][‘panel_type’]. Got None. (See /home/homeassistant/.homeassistant/configuration.yaml, line 81). Please check the docs at https://home-assistant.io/components/envisalink/
2018-02-02 11:30:22 ERROR (MainThread) [homeassistant.setup] Setup failed for envisalink: Invalid config.
2018-02-02 11:30:46 WARNING (Thread-14) [netdisco.ssdp] Found malformed XML at http://192.168.1.37:9080: status=ok
2018-02-02 11:31:06 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform cast is taking over 10 seconds.
2018-02-02 11:31:23 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
I got it figured out. It wasn’t HA at all. It turns out that I can’t have more than one TPI running at a time. I unplugged my Veraplus and everything started working. Thanks
