I have a DSC security system with an Envisalink and it works great with Home Assistant. I also have the google assistant integration. I used to use scripts and less obvious action phrases to arm/disarm my security system with google assistant, but I recently got a garage door opener and discovered the security pin option for google assistant.
The pin works great for the garage door, so I figured it would be good to use that pin option for the security system as well. I exposed the alarm_control_panel
domain to google assistant and I’m running into some trouble.
When I attempt to arm the security system with Google Assistant, I get prompted for the pin. It accepts the pin, but responds with the “Something went wrong” error. When I check the status of the alarm, it is arming. What is the cause for the “Something went wrong” error?
