My problem is when HA starts the log file shows password problem. Here’s the log file entries.
2019-06-11 10:53:46 ERROR (MainThread) [pyenvisalink.envisalink_base_client] Password is incorrect. Server is closing socket connection.
2019-06-11 10:53:46 ERROR (MainThread) [homeassistant.components.envisalink] The Envisalink rejected your credentials
2019-06-11 10:53:47 ERROR (MainThread) [homeassistant.setup] Setup failed for envisalink: Component failed to initialize.
Also after starting I get the following from the dashboard:
But doing a Configuration validation shows ‘Configuration valid!’
I’ve modified and verified my password is good. I’ve also set a password to 4 lowercase characters but it still does not work in HA.
I’m having the exact same problem. My error log is below. I logged in to my EyezON.com account without any issues and checked my username and password multiple times.
Any help would be appreciated.
2019-06-19 10:46:18 ERROR (MainThread) [pyenvisalink.envisalink_base_client] Password is incorrect. Server is closing socket connection.
2019-06-19 10:46:18 ERROR (MainThread) [homeassistant.components.envisalink] The Envisalink rejected your credentials
2019-06-19 10:46:18 ERROR (MainThread) [homeassistant.setup] Setup failed for envisalink: Component failed to initialize.
2019-06-19 11:46:17 ERROR (MainThread) [homeassistant.components.updater] Got unexpected response: None
