I’ve been using Envisalink 4 with my Honeywell panel for a while. Lately I’ve noticed significant delays in the arm/disarm time, and sometimes I don’t get a response at all. When I try an arm command, after a very long delay it sometimes will arm. After it arms, I get the following error in the log. Any thoughts?
A couple notes:
I can connect locally to the Envisalink webpage directly - no delays
I can arm/disarm from the local Envisalink webpage with no delays
The delay appears to be somewhere in Home Assistant
My config.yaml code is included below as well.
Thank you!
Logger: root
Source: /usr/local/lib/python3.8/site-packages/pyenvisalink/honeywell_client.py:104
First occurred: 6:57:33 AM (2 occurrences)
Last logged: 7:05:56 AM
error sending command to envisalink. Response was: Receive State Machine Timeout (command not completed within 3 seconds)
I’m also getting the following in my logs as well.
Logger: root
First occurred: 7:49:43 AM (2 occurrences)
Last logged: 8:36:13 AM
error sending command to envisalink. Response was: Syntax Error. Data appended to the command is incorrect in some fashion
Did you ever get to the bottom of this? I’m having the same issue…can smash the disarm button over and over and nothing happens…other times it is flawless. Likewise from time to time the system will not arm automatically (driven via node-red) or manually (hit the button and try again and again).
I’ve also noticed that sometimes the zone status is not returned to HA - you can trigger motion, see the PIR light up, but the zone sensor in HA still says ‘Clear’…and the panel status stays on ‘Ready’ when really it should be Not Ready if a zone is violated.
It is really frustrating as when it works it’s great so I don’t understand why it goes away with the fairies…
In my case yes - it turns out the Envisalink module is sensitive to certain types of broadcast traffic from other network devices. In the end my problem was UPS software on another device sending broadcast packets that caused the EVL to crash and reboot - so it worked…and then it froze…and then it worked again.
The whole sorry saga is here if you want to see all the details and the fault-finding approach.
For me it turned out my data history logs were too big, which slowed down the response time. After I cleaned up the history logs, everything ran fast again.
