Envisalink - Support for Eyezon UNO-IP
Anyone have success integrating the EyezOn UNO-IP with HA and Envisalink? I called Eyezon support and they told me the panel is based on the Honeywell TPI so it might work? I like the idea of purchasing a unified panel, but don’t want to buy it if the integration doesn’t work.
I am trying to find out the same. It is getting harder to find compatible panels. I gave up on my Networx/Interlogix… HA Plugins says only one user. I guess I was it that was left.
I tried the Honeywell Vista 20P but immediately found the delay in zone closures was unacceptable. So I just tried to buy a DSC 1832 but was just informed by the retailer that they no longer have any stock. Everything is now going to Neo which is not open to development and therefore no integration with HA.
ESP based solutions are not acceptable… I prefer a stand alone, UL certified tried and true system.
UNO looks like it would fit my needs. It says it is compatible with DSC keypads. But based on the response you received, if it is based on the Honeywell TP1 firmware, I could be landing right back on the zone closure delay.
–Chance
What zone closure delay did you experience? At my prior house I had the DSC PC1616 panel with zero issues so I may just look for one of those. Is my understanding correct, I can integrate any zwave/zigbee into HA and Envisalink?
EyezOn told me the UNO security panel has an EVL4 built into it so “it has support and I integration with Home Assistant”.
Anyone have any firsthand experience with the Uno panel from eyezon working with Home Assistant. I’ve just received a panel and have their solo door and motion sensors.
  • The sensors seem to work and register with Home Assistant.
  • When I try to arm/disarm from Home Assistant, nothing happens. Has anyone been able to arm/disarm the system from Home Assistant.
  • When I arm from the eyezon site, HA flashes “arming”, but after the arming process is complete on the eyezon site, HA goes back to the ready state as if the system is not armed.
What are others experiencing?
Hey,
Yes, I was experiencing the same thing. I removed the Enviralink integration and added this new one below that works like a charm.
Same boat has I put together a DSC1832 system parts can be found EPAY was my friend here. Or go with vista control since it’s compatible with eyezon
