Is it possible to add zone attributes for the sensors created by Envisalink integration?
I see this will only be possible for DSC panels, by looking at the code here:
evl_ResponseTypes = {
'505' : {'name':'Login Prompt', 'handler':'login'},
'615' : {'name':'Envisalink Zone Timer Dump', 'handler':'zone_timer_dump'},
'500' : {'name':'Poll', 'handler':'poll_response'},
'501' : {'name':'Checksum', 'handler':'command_response_error'},
'900' : {'name':'EnterCode', 'handler':'send_code'},
'912' : {'name':'PGMEnterCode', 'handler':'send_code'},
#ZONE UPDATES
'601' : {'name':'Zone Alarm', 'handler':'zone_state_change', 'status':{'alarm' : True}},
'602' : {'name':'Zone Alarm Restore', 'handler':'zone_state_change', 'status':{'alarm' : False}},
'603' : {'name':'Zone Tamper', 'handler':'zone_state_change', 'status':{'tamper' : True}},
'604' : {'name':'Zone Tamper Restore', 'handler':'zone_state_change', 'status':{'tamper' : False}},
'605' : {'name':'Zone Fault', 'handler':'zone_state_change', 'status':{'fault' : True}},
'606' : {'name':'Zone Fault Restore', 'handler':'zone_state_change', 'status':{'fault' : False}},
'609' : {'name':'Zone Open', 'handler':'zone_state_change', 'status':{'open' : True}},
'610' : {'name':'Zone Restored', 'handler':'zone_state_change', 'status':{'open' : False}},
#PARTITION UPDATES
'650' : {'name':'Ready', 'handler':'partition_state_change', 'status':{'ready' : True, 'alpha' : 'Ready'}},
Would also be great to add the ability to bypass a zone with a switch created by the integration instead of having to create an automation that sends a keypress to the panel. With this however, I am not able to see if a zone is currently bypassed or not.
