Envislink / Honeywell
Hi
/ Can some one guide me I am trying to setup Envislink / Honeywell panel and I am getting the following error.
Invalid config for [envisalink]: required key not provided @ data[‘envisalink’][‘host’]. Got None required key not provided @ data[‘envisalink’][‘panel_type’]. Got None required key not provided @ data[‘envisalink’][‘password’]. Got None required key not provided @ data[‘envisalink’][‘user_name’]. Got None. (See ?, line ?). Component error: zonedump_interval - Integration ‘zonedump_interval’ not found. Component error: evl_version - Integration ‘evl_version’ not found. Component error: keepalive_interval - Integration ‘keepalive_interval’ not found. Component error: panic_type - Integration ‘panic_type’ not found. Component error: host - Integration ‘host’ not found. Component error: partitions - Integration ‘partitions’ not found. Component error: code - Integration ‘code’ not found. Component error: password - Integration ‘password’ not found. Component error: panel_type - Integration ‘panel_type’ not found. Component error: user_name - Integration ‘user_name’ not found. Component error: zones - Integration ‘zones’ not found. Component error: port - Integration ‘port’ not found.
envisalink:
host: 172.16.15.xx
panel_type: HONEYWELL
user_name: user
password: user
code: '9999’
port:
evl_version: 3
keepalive_interval: 60
zonedump_interval: 30
panic_type: Police
zones:
14:
type: 'opening'
partitions:
1:
