After the last two updates both MyQ and Envoy (enphase gateway) are broken. HA Version: 2021.1.0 Operating System Version: 5.9.16
The third error I don’t know why it’s an issue. Here is my line 136 from my configuration.yaml file.
Preformatted text`136 group: !include groups.yaml
Config entry for myq not ready yet. Retrying in 5 seconds
5:43:48 AM – config_entries.py (WARNING) - message first occurred at 5:40:13 AM and shows up 6 times
Error requesting data from https://api.myqdevice.com/api/v5.1/Accounts/c5ba3d41-b74f-4a38-8f81-e8fdfece085f/Devices: 400, message='Bad Request', url=URL('https://api.myqdevice.com/api/v5.1/Accounts/c5ba3d41-b74f-4a38-8f81-e8fdfece085f/Devices')
5:43:48 AM – /usr/local/lib/python3.8/site-packages/pymyq/api.py (ERROR) - message first occurred at 5:40:13 AM and shows up 6 times
Device update failed; trying again in 2 seconds
5:43:42 AM – /usr/local/lib/python3.8/site-packages/pymyq/api.py (WARNING) - message first occurred at 5:40:02 AM and shows up 18 times
Authentication failure during setup: 401 Client Error: Unauthorized for url: http://192.168.1.110/api/v1/production/inverters For more information check: https://httpstatuses.com/401
5:40:02 AM – enphase_envoy (ERROR)
Sensor type "callhelp" is unsupported.
5:40:00 AM – /usr/local/lib/python3.8/site-packages/pyhik/hikvision.py (WARNING) - message first occurred at 5:40:00 AM and shows up 36 times
Invalid config for [automation]: [for] is an invalid option for [automation]. Check: automation->for. (See /config/configuration.yaml, line 136).
5:40:00 AM – config.py (ERROR)
Myq is a known issue and outside the control of the developers. MyQ has changed their undocumented API again and has broken the integration. Search for the thread.
you restarted after changing configure.yaml ?
what does the log say now? i see you dont have inverters listed under monitored, so it shouldnt be trying to access that page any longer.
