My envoy Solar system stopped working with HA.
I have Swichted my system off for a couple of days and noy Envoy does not connect anymore
I use a Envoy-S standard EU.
Firmware D8.2.4264
HA core: 2023.5.2
HA Supervisor: 2023.04.1
(i know these are older versions but i am running the stuff on docker on my synology NAS which does not support the latests Docker version).
The integration shows automatically with the correct IP addres of my gateway. But logging in does not work.
It only shows failed to connect.
I am using the envoy account which is pre filled in and no password. this does not work
Also my account that i use with the enphase app and website does not work.
I have restarted HA serveral times.
Any suggestions?
Firmware Firmware D8.2.4264 is being pushed out as we speak, at least in the Netherlands, as result of reported vulnerabilities .Firmware versions 7 and higher require to specify the your Enphase account username and password.
Whether your HA version supports this depend which Envoy integration you are using. A custom one or the HA Core integration. But on HA 2023.5.2 the core integration is too old to support token retrieval.
Updating HA running in Docker on Synology is simply a matter of rebuilding the HA container and re-pulling the image. I’m running HA on Synology (DSM 7.1.1) ) NAS docker and that works fine with 2024 releases.
I added a Portainer container on synology docker as well and use that to manage the other containers, way easier as the Synology docker UI.
