Epever UP-HI with Epever TCP-306 (modbus)
Hi everyone,
I have a Epever UP-HI 3000 Hybrid Enverter that I would like to connect to my home assistant via modbus, as Epever’s cloud solution is very buggy.
I have now ordered the Epever TCP-306 and connected it to the inverter. But homeassistant does not receive the correct data. I found out that the TCP-306 is identical to the USR-TCP232-306 https://www.pusr.com/products/ethernet-to-serial-converters-usr-tcp232-306.html.
I will now install a firmware update to v4020, as the new version probably supports multi-host Modbus polling Modbus RTU to Modbus TCP.
I will report here whether it worked.
nice greetings from Germany
Elch
Hello LosElchos :wink:
I have also a TCP306 module to connect to home-assistant.
Did you manage to read data from the module ?
I connect to the module, but probably I dont get the good configuration on it…
Tchuss
Vince
